370Z OEM Wheel Locks on 350Z?
on
Hi guys. So I recently bought a set of 370Z Rays for my 350Z and after powder coating them and some spacers everything is perfectly installed with original 370Z wheel nuts.
In order to put a little security on them I got a set of 370Z OEM Wheel Locks (part number 999W2-JT000) which I was told was specifically for those Rays.
So the problem is I can't get them to fit in my 350Z wheel studs!!!
The original 350Z wheel nuts fit perfectly but not the wheel locks.
Is this normal or am I missing something here?
Thanks
Thanks
on
Thanks you all for your answer and help. I'm giving up on this wheel locks.
After many tries, I couldn't get any of them to properly fit. I even damaged a stud due to the forcing it to fit.
I changed that stud and now I'm ordering a new set of locks from an aftermarket manufacturer:
Thanks you again
Thanks you again
on
What intrigue me the most is that the actual "shape" of the wheel lock isn't the problem.
What really make them not to fit is that the thread don't seem correct even though they are OEM Nissan 12mmx1.25 (as the original wheel studs are)
