What color of Lug Nuts...
Old 07-30-2015, 01:47 PM
350zchad
350zchad's Avatar
Default What color of Lug Nuts...
I have the Black Chrome stockers that I will be keeping because they are bad ***.
I'm wanting different lug nuts, I'm considering Red, Black, or Neochrome.
What color do you all recomend with the looks of my wheels and calipers?
I'm considering extended "tuner" style instead of the closed factory style and size.
Thanks for your input.
Old 08-02-2015, 05:44 PM
SQuaLZ
SQuaLZ's Avatar
I couldn't find any tuner lugs that are acorn for them to work with the OEM wheels. I went with the Gorilla lugs. They come in silver, red, blue, and black. I had blue for a while then switched to the black. The blue stood out too much IMO.
I would go with black, although the red might look good with the calipers.
Whatever you do, don't get the flat angle lugs. You need the acorn or else they will loosen over time.
Old 08-02-2015, 05:59 PM
350zchad
350zchad's Avatar
these are the style I'll be getting, they have a ton of colors and should fit our wheels fine, no?
Amazon.com: Muteki 32905T SR Series Chrome Titanium 12mm x 1.25mm SR48 Open End Lug Nut Set, (Set of 20): Automotive Amazon.com: Muteki 32905T SR Series Chrome Titanium 12mm x 1.25mm SR48 Open End Lug Nut Set, (Set of 20): Automotive
Old 08-02-2015, 09:57 PM
mr. sparco
mr. sparco's Avatar
Red to match the calipers.
Old 08-03-2015, 02:30 AM
dSpaceman
dSpaceman's Avatar
Seems a little too tacky, for me anyways
Old 08-03-2015, 08:04 AM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Those look awesome.
Black or purple.
Old 08-03-2015, 08:19 AM
mr. sparco
mr. sparco's Avatar
I like it.
Old 08-03-2015, 09:53 AM
Phenom
Toasty
Phenom's Avatar
Received 1,382 Likes on 990 Posts
Personally I disagree
350zchad (08-03-2015)
Old 08-03-2015, 02:51 PM
mr. sparco
mr. sparco's Avatar
I also like what this guy did, one red lug to match the caliper, decal, and valve stem.
jhc (08-04-2015)
Old 08-05-2015, 07:44 AM
SQuaLZ
SQuaLZ's Avatar
Chad, the link you posted are lugs that will fit, but will not stay tight.
I did my research when I wanted to get lugs myself. Unfortunately almost all aftermarket lugs are to be used with aftermarket wheels.
That is why I got the Gorilla lugs. To my knowledge they are one of the only companies that sell the type of lug that works with the OEM wheel on the Z. Tuner lugs are flat angled, while if you look at the stock lug it is rounded, hence the name acorn. You need acorn lugs or else you are running the risk of them coming loose over time.
Old 08-05-2015, 07:57 AM
350zchad
350zchad's Avatar
I don't know shiet about lugs just going off what I've read, but will look into gorilla instead, thanks for the tip!
Old 08-05-2015, 08:43 AM
SQuaLZ
SQuaLZ's Avatar
No problem. I didn't know much either but someone had mentioned it to me and after researching I figured I didn't want to risk it.
IMO Gorilla is great quality, you will not be disappointed.
sales@czp
09-23-2019 03:30 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
Quick Reply: What color of Lug Nuts...
