Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
FS: Aftermarket TPMS for Nissan
Old 10-22-2015, 06:30 AM
carid
Vendor - Former Vendor
carid's Avatar
Default Aftermarket TPMS for Nissan
If you are buying new rims or tires for your car - don't forget about the TPMS sensors. A lot of modern vehicles are equipped with these little devices that make our life easier, so it is needed to maintain and replace them when necessary.
Aftermarket TPMS sensors are often many times cheaper than OE sensors and designed to work with pretty much any kind of wheels. Here at CARiD we offer sensors that fit over 90% of the vehicles on the road. They program for your vehicle using the exact same procedure as you would use for the factory sensors. Be proactive, properly inflated tires save money due to better fuel efficiency, they are safer and last longer.
There is a reason why the TPMSs are mandatory, they are essential for safety, will provide you with better fuel efficiency and maximize the life span of your tires. Don't forget to replace your sensors when mounting new tires; this way you won’t have to pay to have the tires remounted and balanced again if the sensors fail shortly afterwards. If you have 2 sets of wheels for summer and winter use - just get an extra set of TMPS sensors and forget about switching them from one set to another.
Note: If you’re buying new wheels from us, order the TPMS sensors at the same time. We’ll install them, and mount and balance the tires before we ship them to you.
Doing regular vehicle maintenance is one of the keys of safety on the road. Check out our wide selection of TPMS sensor here: http://www.carid.com/tpms-sensors.html
Stay safe!
carid is offline
HipHop615
Intake
11-03-2015 09:49 PM
spacemn_spiff
Accessories
10-23-2015 05:16 AM
Gunal_D
10-23-2015 05:04 AM
Bak3rme
10-19-2015 06:26 AM
Quick Reply: FS: Aftermarket TPMS for Nissan
