New to me 07 Roadster and want to go "square"
on
Just picked up an 07 Roadster that I will be using as my daily driver. I've read through a number of the threads and am a bit confused as there seems to be contradictory info in the various threads I've read. I'd like stay with OEM wheels and want to be able to rotate the wheels to increase the life of the tires. Should I add the larger rear wheels to the front or should I pick up a pair of the front wheels to add to the rear? What, if any, issues will I encounter?
350Z/370Z Tech Moderator
If your car is equipped with VDC, there's a slight chance that you'll upset that balance as it's looking for higher front wheel speed (smaller diameter than rear) but I've not heard of many - if any - people having an issue with that so long as you stay sane on tire sizing.
I’ve run my VDC equipped 350z with an all square setup (identically sized tires front and rear).
The best results were using the stock rear tire diameter size all around (and not the stock front tire diameter on all four corners).
