19x9.5 19x11 tire stretching need help
Old 06-09-2016, 09:19 AM
Cory350z
Cory350z's Avatar
Default 19x9.5 19x11 tire stretching need help
Stock suspension I don't want anything crazy just somthing enough that it looks 'stretch' I can get 215/35/19 and 275/40/19 for 50$ They would go on Zedd rims I also have a roadster I'm new to this thank you!
Old 06-09-2016, 09:24 AM
HRMoneyPit
HRMoneyPit's Avatar
Ugh
Idk where to start going in on you
Old 06-09-2016, 09:32 AM
Cory350z
Cory350z's Avatar
Originally Posted by HRMoneyPit
Ugh
I mean I'm not dumb man I just not the best at using forums I've read other comments saying it's okay and shouldn't rub but I just wanted to double check but the offset were like +12 +15
Old 06-09-2016, 09:36 AM
Vena14
Vena14's Avatar
I just had my new Bridgestone Potenza S-04's put on yesterday in 265/35/18 and 285/35/18 on a stock suspension. I poke in both the front and the rear without spacers. The entire setup with tires shipped from tire-rack and mount + alignment was $1,200. I could not imagine what $50 tires would feel like and I would hope they are used at best for that price.
Cheaping out in an area like the tires in one of the biggest mistakes you can make. That is both the first and last contact your vehicle makes with the road. They are the vessel in which the power in delivered and how you stay on the road and not in a ditch or around a tree.
edit: I'm also on Enkei rpf1's 18x9.5+15 18x10.5+15
Not to say that you can't find good deals but I would be nervous about purchasing any major component of a car for $50 especially one driven in such a spirited manner as a Z. If you do choose to post again do some research or at least put some thought into your post because you're about to be in for a treat.
Old 06-09-2016, 09:44 AM
Cory350z
Cory350z's Avatar
Why do you guys try to get on someone so hard damn I'm not dumb I understand you DID NOT ANSWER my question at all whatsoever the tires are used from my buddy good god you can can't even get tires that size for 50$ forget it man you guys are no help at all I just wanted my question answered smh....
Old 06-09-2016, 09:50 AM
Vena14
Vena14's Avatar
I have about three and two fingers gap front and rear sitting on 265/35/18 and 285/35/18. You have both a larger wheel size and the same or larger tread wall. The rear I can see being especially problematic and most car manufacturers give the front fender a deeper cut than the rear.
The real issue here is that by googling "275/40/19 on a 350z" over 5 similar threads appeared. You could have saved yourself time by seeing if your question had already been asked. These are over ten year old cars that are highly modified. I'm sure by now almost any Z related question you have had has been answered many times over.
Old 06-09-2016, 09:53 AM
VO...
Administrator
VO...'s Avatar
Received 2,747 Likes on 1,836 Posts
Vena's post wasn't very harsh at all. It was pretty sound advise. It wasn't sugar coated, but honest and to the point.
A much harsher response would be from one of the OGs. Those are gents you have to watch out for.
Welcome to the forums. Take care and enjoy your stay sir.
VO...
Old 06-09-2016, 09:56 AM
Cory350z
Cory350z's Avatar
Read my previous comments man.. I've already read it... They say it will work I just want to have my own conversation about but I'm alittle confused why is that a problem? I feel as tho the front will be okay 215/35 but the rear 275/40 won't fit and will rub
Old 06-09-2016, 09:59 AM
turboed350z
turboed350z's Avatar
Let me chime in and be extra harsh....
First of all, 215, thats civic fitment. You want to rock civic tires, go buy a civic.
Secondly, 215 up front, that back end is going to end up in alot of ditches and smack alot of poles...
Thirdly, 215f and 275r thats WAYYYYYY out of balance in twrm of handling for the car... 50 bucks per tires... no wonder why, crap tires cheap price used or not the size is crap.
Fourthly, i didnt even read the thread all the way through and already i can tell 215 and 275 on 11 wide is going look like the kid on the short bus licking the window.
But to answer your question. Nope no rubbing will happen (especially if youre jdm AF and camber the crap out of the wheels. #swag #yolo #stancenation)
Old 06-09-2016, 10:02 AM
Vena14
Vena14's Avatar
Ahh, I see. You don't understand what the numbers actually mean in relation to the tire. When a tire is a 215/35 or a 275/40 that means it is 215 mm wide and the 35 refers to it's aspect ratio or tread wall. The 35 means that it is 35% of the 215mm tall.
This creates a problem when you go up to a 275/40/19 because not only have you increased the size of the wheel (rim) but you have also increased the "height" of the sidewall. This happens because you now have 40% of 275 in the rear. I want to say a stock Z runs 225/45/18 245/45/18. The fronts will fit no problem I believe. If there is an issue you will find it in the rears.
Old 06-09-2016, 10:05 AM
jang0
I luv TH
jang0's Avatar
Old 06-09-2016, 10:06 AM
turboed350z
This creates a problem when you go up to a 275/40/19 because not only have you increased the size of the wheel (rim) but you have also increased the "height" of the sidewall. This happens because you now have 40% of 275 in the rear. I want to say a stock Z runs 225/45/18 245/45/18. The fronts will fit no problem I want to say. If there is an issue you will find it in the rears.
Well that would also depend on the amount of camber he runs.
Im lowered in ebaich prokit. Im running 275/40r18 and i only SLIGHTLY rub. Admittedly im only 9.5+22 in the rear. Rolling my fenders would give me PLENTY of clearance.
So assuming stock height, with 11 wide, (no clue on his offset) if he rolled the fender and camber it a bit, he *should* clear the rear with 275/40
Old 06-09-2016, 10:08 AM
VO...
Administrator
VO...'s Avatar
I agree. I have 9.5f and 10.5r. I run 245f and 285r. I can't even imagine how the from end would take a high speed curb with 215s...
Old 06-09-2016, 10:09 AM
Cory350z
Cory350z's Avatar
Thank you finally a legit answer what would you recommend for the rear tire size with the stock suspension? I'm not trying to rock the civic look I would like to avoid camber I'm okay with alitte wheel poke
Old 06-09-2016, 10:10 AM
Cory350z
Cory350z's Avatar
So 215 is out of the question thanks man
turboed350z
I thought recommended way 255/285 or 265/285, is there a reason you went with 245 instead?
Old 06-09-2016, 10:12 AM
Cory350z
Cory350z's Avatar
Offset +15 I would like to avoid camber but with 19x11 I don't think I will be able to
Old 06-09-2016, 10:13 AM
Cory350z
Cory350z's Avatar
Why be harsh man I just said I was new? Why be an Ahole? No one really in my town even attempts to stance their car I don't want the civic look that's why I'm asking for help.. I wanted my own conversation so I would actually understand it
Old 06-09-2016, 10:14 AM
turboed350z
Well then... it appears you are in a pickle... 275/40r19 on 11 wide+15 is gonna have you rubbing like no tomorrow
Old 06-09-2016, 10:17 AM
Cory350z
Cory350z's Avatar
okay thank you now what can I do to avoid that? What tire size without camber with avoid it? Then what tire size with alittle bit of camber I know nothing about camber yet but if I HAVE to do it I will do research
Quick Reply: 19x9.5 19x11 tire stretching need help
