I need your advice please
Old 08-24-2016, 06:49 AM
Touring08
Touring08's Avatar
Default I need your advice please
Hello everybody,i have a 08 350z conv touring. The hub i believe its a 66.1,but there are rims i want to buy,but the rims hub is 73.1mm. What size of spacers will i need? Any advice will be greatly apreciated guys.
Old 08-24-2016, 07:03 AM
iideadeyeii
iideadeyeii's Avatar
Troll post. /lock thread
Old 08-24-2016, 07:14 AM
Touring08
Touring08's Avatar
Dont know if i posted in the wrong section,but im not a troll. I just purchased my car not long ago,dont know much about it. It might sound like a stupid question to you,but not for me sir.
Old 08-24-2016, 07:19 AM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
A better solution would be to buy wheels with a lower offset to get the look/ride you want. Offset in the mid teens to mid twenties.
If you need a source for new spacers, start here.
https://www.z1motorsports.com/brakes...mm-p-3118.html
Old 08-24-2016, 07:24 AM
Touring08
Touring08's Avatar
Thank you so much, you been kind enougg to point me in the direction. Have a great day
Old 08-24-2016, 07:36 AM
jhc
jhc's Avatar
You're welcome, we all start somewhere. I went if 18" Enkeis, 9.5FR , 10.5RR.
+12 all around, and I like the fit without spacers. Good luck!
Old 08-24-2016, 07:47 AM
Touring08
Touring08's Avatar
Thank u so much
Old 08-24-2016, 07:48 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
The basic question.... hub centricity NOT spacers!!
73.1 wheels to 66.1 hub require a set of these:
http://www.ebay.com/itm/4-Hub-Centri...FWMEnM&vxp=mtr
If you do decide to use spacers (a whole different topic), get 66.1mm hubcentric spacers but wheels will still need hub rings (above) because the hole's too big.
Down, boys.
The following 2 users liked this post by MicVelo:
35th4me (08-24-2016), Touring08 (08-24-2016)
Old 08-24-2016, 07:55 AM
dcains
dcains's Avatar
What wheels (not rims) are you looking at?
Old 08-24-2016, 08:07 AM
Touring08
Touring08's Avatar
Look at this on eBay http://www.ebay.com/itm/252497982088
These are the ones i want for my car,wich is redline red
Old 08-24-2016, 08:12 AM
dcains
dcains's Avatar
Oh no, that's what I was afraid of. regardless of the look, which is open to interpretation, those are just not wheels you want on your car. You need to consider build quality, weight, safety, size/offset, etc.
The offset, at 38mm, is too far off to correct with spacers, and frankly, those wheels are junk quality. Not for any Z, trust me. Please look at some of the threads in the wheel/tire section and get some better ideas.
Old 08-24-2016, 08:15 AM
Touring08
Touring08's Avatar
I sure will thank you
Old 08-24-2016, 08:19 AM
dcains
dcains's Avatar
You're correct about wanting 18's, but you want strong and light, not soft and heavy. And, offsets in the 15-20mm range. If you're patient, some nice used wheels may come along. Maybe a used set of Rays V1 track wheels? They're the best bang for the buck, and they're forged, super-light, and they fit correctly. I've seen the in the $600 range.
Old 08-24-2016, 08:52 AM
MicVelo's Avatar
^^^^ This.
To add to that.... replica wheels are generally fine for light use (I know some might chuckle at MY saying that given my recent endeavor of trying to break a set unsuccessfully) but.... these aren't even replicas. And at $378 for a SET(!), well, you get what you pay for (or didn't pay for as it were.)
Try to avoid dual drilled wheels, e.g. 5x100 AND 5x114.3. You have to consider that this takes even more strength out of the hub area, which is the biggest source of loading on any wheel (and usually the SPOF).
It's a mfgr's way of cheaping out on manufacturing to meet too many uses.
Old 08-24-2016, 06:33 PM
rearranged
rearranged's Avatar
And definitely get wheels wider than 8"
Old 08-24-2016, 08:20 PM
Spike100
Spike100's Avatar
Be sure to check-out Enkei wheels before making a purchase.
Enkei wheels are an exceptional value, and are available in ideal widths and offset for the 350z.
Zajac
Wheels Tires
05-06-2016 02:33 PM
carboyanno
05-05-2016 07:28 AM
KobeIsGOAT
04-14-2016 09:46 AM
Magicparra
04-11-2016 12:34 PM
DaveNunez
03-16-2016 03:16 AM
Quick Reply: I need your advice please
