Found wheels i like but carid says they do not fit not sure why
General & Tech Moderator
Back in the day when I was a printer, I had a great triple beam scale, but only up to 440 grams...
on
What brand of spacers should I look Ino? I find them from 50 bucks all the way to 170. Z1 has a spacer kit with studs and plate for 78 bucks. Does a 20 mm spacer match the wheel to fender the same as the rear wheel to fender?
6 inch cawk is my fave!
I would say if your going to use spacers the ARP extended studs and slip on is the only way to go, and then your spending $240 $ and you still have oem wheels with spacers... They have decent wheels for less than $250 each available on tire rack, and if you have a distribution center near you can pick up for free.
Lulz @ dboyzalter
on
There isn't any tire rack center near me and I can get the arp studs and spacers from z1 for 120 for the front two. Does it have to be 20mm or does 15 mm spacers work? I have looks over and over on tire rack and discount tire but for any thing less than 275 a wheel I don't like them and I like the look of these factory rays wheels. Plus since I'm painting the car right now I can sand and paint them black with a blue pearl to give a nice look to them and not feel bad about it.
jhc (10-02-2016)
