Fixing my XXR 18x10 +25 Square Setup
Old 01-07-2017, 04:58 PM
rocketpanda40
rocketpanda40's Avatar
Default Fixing my XXR 18x10 +25 Square Setup
So I just purchased XXR 521 18x10 +25 all around along with HTR Z III 275/35f & 275/40r tires. I was going by the advice here: https://my350z.com/forum/wheels-and-...ll-around.html
The guys at the shop test fitted the fronts and said they were hitting the control arms --I've got an 06 vert at stock height. They didn't mount the rears though I would assume based on what I've read, they should fit fine, just sunken a bit. I've seen a few people on this forum seemed to have success with 18x10 +12, so would I be able to run a 10mm spacer in the front to clear the control arm? If so, would I need to roll the fenders to not rub? Should I run a 5mm wider (wider than the front) spacer in the rear to fill the fender better?
I don't care for my car to be super hellaflush, I just want to make these wider wheels work if I can. I plan to mildly drop the car eventually but right now I'd rather not have to buy camber kits.
Thanks in advance for any help!
Old 01-07-2017, 08:24 PM
nizmo_0385
nizmo_0385's Avatar
rear will be fine as is. you can add 10 to 15mm spacers to be flush back there.
the front should clear with a 5 or 10mm spacer. Front fender is already rolled just remove the middle fender liner screw so it doesn't cut the tire.
Old 01-07-2017, 09:04 PM
rocketpanda40
Great, thanks for the quick reply! So just to be clear, 10mm front and 15mm rear spacers should clear and be (relatively) flush without needing to roll any of the fenders? I'll definitely remove that screw!
Old 01-07-2017, 09:12 PM
nizmo_0385
nizmo_0385's Avatar
I believe the rear will be fine at stock height if you do any lowering you will need to roll the rear
Old 01-07-2017, 11:58 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
^^^ This.
"Flush" is relative. With the specs of your wheels, you're already bringing the wheel OUT by over an inch (27mm to be precise). 15mm spacers will bring the total to 42mm with an effective offset of "only" +10mm. It's an even bet you'll need to roll. (This figure is in relation to stock wheels.... 18x8.5 +33 or smaller)
Before you rush out and buy a set of rear spacers, I'd advise you try the wheels/tires as is. In 10+ wheel sets, I've never had to roll my fenders until I went with a +15mm offset. Have gone up to 11" wide +25 with 295/35 rears with no issue.
And this is a puny 9.5" rear wheel.
Old 01-08-2017, 08:36 AM
rocketpanda40
Originally Posted by MicVelo
^^^ This.
Thanks for the input! As I said in the op, I honestly don't care about being super flush. The reason I was thinking about spacers in the rear is because it's a square setup, I thought it might look weird if I spaced the front and left the rear as is, like a reverse stagger?
Would you agree that a 10mm spacer up front with the factory rolled fenders would clear the suspension and not rub?
I can definitely leave the rear as is for now and roll/space later if I need to
Old 01-08-2017, 08:47 AM
MicVelo's Avatar
To be honest, I don't know why your +25 offset aren't fitting as is. But, guess the wheel and tire widths are pretty large - however many times I've seen people go 275 square.
I can't begin to tell you whether 10mm spacers will work since I've not seen any issues like this. (I run 20mm spacers to accommodate high offset Z34 wheels but none for clearance.)
Old 01-08-2017, 11:07 AM
rocketpanda40
Well, I used this calculator: http://www.willtheyfit.com/index.php...t2=25#isPage=1 and went out and measured my car and the rears will definitely be just fine. I may space them if/when I get a drop. In the front I had a little trouble getting the tape measure in there and reading it accurately, but it does seem like the wheels *should* fit in the front...
Just to be safe and not be told they won't fit again, I'm gonna grab some 10mm spacers (which should make it just about flush too, by my measurement). Will post pics when I get them in/installed.
Old 01-08-2017, 11:54 AM
nizmo_0385
nizmo_0385's Avatar
I'm running a front 19x10 +20 with 10mm. spacer. previous +30 and no clearance issues. I have 275 35 up front. op you may just need to mess with alignment vs needing spacer as I don't need spacer to clear
Old 01-08-2017, 12:01 PM
rocketpanda40
Agggh I'm so confused/torn! In fairness, with a 19in wheel the rim is higher which due to the control arm shape gives you a *little* more clearance. But from all the threads I'm finding, especially dexrod's car (as seen here and elsewhere: https://my350z.com/forum/350z-roadst...s-here-76.html), I'm starting to think you're right, the car just needs alignment.
In truth, I've worked on my car a little bit (I've installed mrev2 + spacer and an intake), but I'm letting a shop handle mounting the wheels and tires. I would have thought they would know if fixing the alignment would get the wheels on but they just said to space it. Maybe I should take it somewhere else first and see what they have to say before buying spacers?
Old 01-08-2017, 12:03 PM
nizmo_0385
nizmo_0385's Avatar
in my opinion they are playing it safe and test fit there's no way it hits. it looks like it will with suspension free but once it's on the ground the car camber and gives more clearance. if 10 +25 were hitting no one would run it. that's a pretty common front. like I said my front is 10 +30 5mm closer to control arm and no issue. I added a 10mm just to make it even with my rear +20.
Old 01-08-2017, 12:11 PM
rocketpanda40
Thanks for the input! I'll definitely look into taking it somewhere else first before I buy anything, and then look into a drop before spacing if all goes well.
Old 01-28-2017, 11:16 AM
rocketpanda40
Thanks again! I got them on at another shop about a week ago and they're great I think I am gonna space the rear 10mm probably, but I'll wait til I drop it. Found a set of Eibach Pro Line for $600 local so I'm gonna see if they still look good.
Here's a pic:
Old 01-28-2017, 11:18 AM
nizmo_0385
nizmo_0385's Avatar
Here's a pic:
Told you bro! They look great! Enjoy man!
Old 01-28-2017, 01:22 PM
No_name
No_name's Avatar
Lookin' good.
