255/45/18 on stock 350 rim?
Old 02-22-2017, 04:54 PM
Teluga
Teluga's Avatar
Default 255/45/18 on stock 350 rim?
Anyone advise against 255/45/18 bfg g-force comp 2 -A/S on stock 06 rims? Also will 255/45 look odd with the stock 225/45 in the front? Thank you!
Old 02-22-2017, 06:24 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
Using the "1.2 Factor" (that is, a tire's width should not exceed 1.2x or 120% of the wheel's width) for MAX PERFORMANCE. You can physically mount a tire up to as much as 1.3 or even 1.4x the wheel width but your performance/handling drops off. This works fine for trucks but don't recommend for a Z.
Doing the math..... an 8.5" wheel x 25.4 = 216mm
216mm x 1.2 = 259mm max tread width. Obviously, 255 is right in range.
Teluga (02-22-2017)
Old 02-26-2017, 03:20 PM
rearranged
rearranged's Avatar
I'm running 255/40 on the rears with 245/40 on the front. What exactly do you mean by look odd?
Old 02-26-2017, 04:27 PM
Spike100
Spike100's Avatar
It won't look odd, but you will experience significant understeer with the setup you describe.
