MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   2003-2009 Nissan 350Z (https://my350z.com/forum/2003-2009-nissan-350z-2/)
-   -   Lowering with 19's or not ? (https://my350z.com/forum/2003-2009-nissan-350z/101410-lowering-with-19s-or-not.html)
aykut Dec 5, 2004 04:44 PM
i like to know something , i plan to buy 19's volk sf challanges with 245-35-19 for the front and 275-35-19 for the rear
do u guys think i need to drop it a little bit ? Because i am kind a worried about gap issues and dont want to see the car like a SUV so what people usually do ? Use stock suspension or get a eiabach pro kit or any other spring,coilover system ? thanks
onii Dec 5, 2004 04:57 PM
if u got the $, go for the coilcovers, otherwise, the eibachs will give u good drop. i havent dorpped mine yet and it looks silly
kcobean Dec 5, 2004 06:31 PM
Believe it or not, 19" wheels with the tire sizes you specified have a smaller circumference than the 18" Track Rays due the the shorter sidewall. It is perfectly safe to lower your car approx. 1 inch. You will have no rubbing issues. I have the Eibachs on my car and am going with a similar wheel. I know for sure that I'll have no problems.
Jason@Performance Dec 5, 2004 08:28 PM
Depending on the offsets of the wheels you will not have any rubbing issues... but if you have a very aggressive offset even on 17's you will rub if you lower the car...
ssc Dec 5, 2004 08:30 PM
for me, it is must that i drop my car when i get rims. if i did not want to lower my car, i wouldn't get rims...i think there is nothing more unsightly than a car with nice rims but a large gap between the wheel and the body.
get coilovers.
shinz Dec 5, 2004 09:12 PM
I have +22 offset with my LE37's on 245 front, 275 rear. Do you think it'll rub with the Eibach springs?
Jason@Performance Dec 6, 2004 12:01 AM
you will get very close and may rub a little bit... i would recomend rolling or cutting your fenders...
with the NISMO 18x9.5 +30mm with 275/40/18 (same diameter as what you have) I rubbed on eibach when taking corners very hard
LanceG33 Dec 6, 2004 09:37 AM
I have 19s and a Greddy front lip. The front lip is definetly lower than stock. With the steep hill that leads into my building's garage I would scrape the front lip everytime if I was any lower. . . I have about .5" of clearance when I take the hill at an angle.
Consider your daily routines and hills in your area before you drop - especially with a body kit.
