trunk door doesn't stay up
hey everyone,
Just wondering if anyone has this problem. Sometimes when i open the trunk door of the Z, it doesn't stay up. It looks like it doesn't have enough strength to stay up and just shuts down. Any experience this before? |
I've had the same problem with mine. It only does it every once in a while. :confused:
I noticed if its cold out the hatch won't stay open.
Plunk a Viagra in the gas tank.
(Bad joke, but it HAD to be said! LOL) |
Originally posted by tjhands Plunk a Viagra in the gas tank. (Bad joke, but it HAD to be said! LOL) |
I had the same problem especially when it was cold. When I took my car in for the hatch release TSB, they also replaced the hatch struts. The story they told me is that there is some type of ball valve inside the strut that gets stuck in the open position and it's more sensitive when it's cold.
Originally posted by Aggro_Al I had the same problem especially when it was cold. When I took my car in for the hatch release TSB, they also replaced the hatch struts. The story they told me is that there is some type of ball valve inside the strut that gets stuck in the open position and it's more sensitive when it's cold. |
It's probably the fluid in the hydraulic thingy. When it's cold it probably gets thincker and doesn't move as freely.
do you have a wing....i think some ppl with rear spoilers have experience this problem
Originally posted by etan hey aggro, so i can take it in and have them replace it? For those that have aftermarket wings, make sure the weight plate in the back is removed. If your Z came with the stock wing, chances are that the plate was already removed. Just check to be sure. |
| All times are GMT -8. The time now is 04:50 AM. |
