Back wheels hopping
on
Back wheels hopping
I have a 2005 Base 6MT, and whenever I launch my car at about 2k RPM, the back ends starts hopping like a kangaroo. The tires are not being burned, or making any noise. They just simply hopping up and down. Needless to say, i basicly get killed everytime I try to race with someone. any idea how to fix this problem guys?
on
NEW SPRINGS.
simplest solution. the nissan springs suck which cause that wheel hop as well as porpoising on bumpy roads. Nismo springs cure the wheel hop, the nismo suspension (as wheel as several others) will greatly reduce the porpoising.
good luck
good luck
ive never thought about how changing the springs would affect the wheel hop, but now that you mention it, wouldn't stiffer spring rates (specifically in the rear) actually make the wheel hop worse since the stiffer rates would allow less transfer of weight to the rear when you launch?
I switched to the Eibach pro-kit springs, which are a progressive rate spring. Using a non-linear rate spingWhile I don't do burnouts very often, the "freeway bounce" is gone. I'll second the recommendation that if you're losing traction enough to start the back wheels bouncing, you're applying too much gas.
20 years ago you would correct this with traction or ladder bars. They essentially kept the rear axle from twisting, and very effectively prevented axle hop.
Because they reduce ground clearance, they are used more on trucks than cars. I did find these for Honda's http://www.modacar.com/products/Honda/Civic/MODATRB/
This explains axle hop http://www.rockymountainsusp.com/tractionbars.htm
If you had anything other than a base model I'd be recommending an engine dampener.
But you my friend need a LSD. If you just bought the car, maybe they will let you exchange it for an enthusiast model? If you negotiate right, it might not be that much more than the cost of buying and installing an aftermarket unit and you get the added benefits of homelink, HID lights, etc.
Originally posted by all_bark
even Z's with LSD get wheel hop.
guys, do a search. springs help the hop dramatically.
it did for me!
it did for me!
I know you are right on with the springs...I just wouldn't want to live with a drag race suspension everyday. You did make me think about a compromise though...adjustable shocks. You could soften up the fronts and remove the sway bar to get some better weight transfer at the strip.
Curious...do you have a base model? Sounds like you drag a lot. Have you found that you get better times launching at higher rpm with some wheel spin or launching lower with no wheel spin, letting the torque pull you out of the hole?
The later seems faster to me...
on
it's not the whole back of the car hopping... it's only the rear axle.
by changing the spring rates, you end up putting more weight onto the rear wheels, reducing the chance of wheel hop purely by increasing pressure and traction.
as for rearward weight transfer, that would apply only after the springs are fully compressed and basically reach a point of infinite pring rate... the wheels would stop hopping, but a lot of your acceleration will have been dampened by the rear springs, making you slower off the line.
