Synthetic Oil
on
My advice is not to listen to anyone here. Dont listen to anyone about extending past the recommended 3750. Take a sample of YOUR oil at 3750 and send it to Blackstone. If it looks good, take it out to 5K and Blackstone. Anytime you change your interval, you should make sure your wear is ok. The bottom line is the dealer isnt going to cover your engine based on what you heard on the internet. If youre extending your intervals (with schedule 1 driving), you need to cover your own ****. Blackstones will allow you to deviate safely from 3k/3750 industry recommendation. They set those for a reason. Its the lowest common denominator for all driving. Some conditions do not allow for more than 3000-3500 miles without increased wear. Thats only a small fraction of people, but it applies to some.
When you start pushing past 7500, be able to accept this
http://www.g-owners.com/pic_display.asp?id=333
its the likely result I've seen with the VQ. Regardless of what syn was used. Check out some 10K ODIs on maxima.org (also VQ). I seriously doubt any of you would do that with your cars.
on
I have seen this stated a lot but I don't think the oil tests bear it to be true. I ended up going 3k w/ my first oil, and then went right to synthetic. I read a lot about this on the bobistheoilguy.com and I never saw any good data that running dino oil did a better job of breaking in your vehicle. As many people there noted a LOT of high performance cars come straight from the factory with synthetic and don't require abnormally long break in periods.
Originally Posted by Zshazz
Like I said above, about the 6k-9k mark is best. This allows all the engine parts to wear properly so they are basically mated together. Where many people make their mistake with synthetics is that they believe that they should change to synthetic at the 0 mile mark. The fact that synthetics decrease the wear means that the engine may not be fully broken in until as high as 12,000 miles if you did that! 3k is usually when the engine is "fully broken in" but you should have the engine slightly more worn in than that before you switch to full synthetic to make sure. So, approximently 6k-9k is my recommendation.
on
I just changed to a synthetic blend over the weekend as my car finally hit the 1000 mile mark in my 5th week of ownership. The dealer tried to talk me into a full synthetic oil change, but PrimeX was not down. As soon as I received my car back (dealer installed aero kit) I noticed much smoother gear shifting in the MT with the synthetic blend. Is this more noticable with a full synthetic change?
on
Originally Posted by sprmario
I have seen this stated a lot but I don't think the oil tests bear it to be true. .
on
I switched to Mobil 1 at 12k miles and my car is running much more smoothly. I'm really pleased for spending the extra $ for it.
The guy at the shop said that they were going to be offering Redline soon. It was like $100 and would supposedly last a hella long time. Anyone here use Redline?
on
by lasting, yes it will have additive left and will not have shifted viscosity, but that doesnt mean you'll be able to safely use the oil that long. Some German cars have 2x the oil capacity and sump type filtering, so you cant compare those cars that allow 12K+ changes.. We just cant seem to do that with the VQ, even with the best oil.
on
I probably looked at 10 to a dozen reports on the VQ35. i'm not sure I interpreted the results right, but I remember noticing that the metals don't settle down till around 7.5k to 10k, but i saw the same results using dino vs. synth early on. I didn't really look at reports from 15k to 20k and compare people who changed early vs later, though. i'm coming up on 5k miles on my first synthetic change and I plan to send in a sample for analysis.
I'm using Mobile-1 10w30 which seemed to be a good choice for those in hot climates (I'm in Miami, FL).
Originally Posted by tware
I gotta give you props for doing your own research and making your own decision. However, make sure youre only considering data on the VQ. The VQ is one of the last remaining engine that need a lengthy break in. If you look at my oil analysis linked above (or any low mile VQ), you'll see the VQ does not settle down until at least 5K. The VQ reports I have read (sorry dont have time to chase the links, but maybe later) did show that an early switch led to less than satisfactory results. At 10-12K, fuel dilution and break in metals were still high. A few people repeated this on the 2k2+ maxima (VQ35 like us) and also had to wait to 15K or higher for the engine to settle down and smooth out. Why delay the highest mpg and HP? Plus with the risk of oil consumption from the seals, its simply not worth risking with a early syn change. However, all you can do is see trends. Your engine may be fine with an early change, many are... it's just that the trending with oil analysis doesnt support that.
on
Originally Posted by SB Track
I use synthetic Mobil-1 just because you can tell that it runs smoother than normal. I still will change every 3k miles with a new filter too.
on
on
i am sitting at 6800 miles on my 05/ i am going to switch to Mobile 1. i live in NW Florida. do you guys recommend 10w-30 or 5w-30? also which Mobile filter fits the Z? and lastly, is it the consensus here that it is quite safe to go 5000 miles between oil/filter changes with Mobile 1 products?
on
Originally Posted by zand02max
12K miles and its still a gold color, Yeah Right!
on
I went syn at 4500, but I had alot of hours on the engine because of 90% city driving and my breakin metal wear was settling.
on
Originally Posted by thirdjoe
I just got my 350Z a week ago. I only have about 500 miles on it now. I want to run synthetic oil in it. At what point is it safe to make the switch to synthetic oil?
Joe Gaines
350Z Performance
Silver Chrome
Joe Gaines
350Z Performance
Silver Chrome
on
on
I've gone synthetic in several vehicles and I'm not going to bother anymore starting with this one. As a long time synthetic user, I've converted and I no longer feel it matters. I'll change it with dino as recommended by Nissan on their schedule and not worry about it anymore.
on
on
I asked my service guy at the dealership about synthetic. His reply was "This is the only car I know of that the owner's manual specifies NOT to use synthetic, the Nissan engineers must have had a reason, but I don't know what it is."
#39
on
i think that the synthetic oil is the best choice for the car.
but i heard that you can't put it unless you break 12k with your car (if it's new)
but it costs a lot in US, here it costs around 12$ for Mobil 1
#40
Due to new posts stating that it takes the VQ abnormally long to break in normally, I'd actually recommend you sticking with conventional oil for at least 15k, possibly even 24k to make sure the parts are fully broken in.
And by the way, I think people misunderstand the whole extended drainage things. You still have to change your filter, the idea is that you just catch your oil in a pan and put it back into your engine. People are putting in filters that are suppose to last for 3000ish miles in their engine and then running it for 7000 miles and saying that the oil is bad because the filter couldn't filter everything out anymore. The idea is to change the filter when it recommends, but keep your oil because your oil is the most expensive part (at least if you get a really expensive extended drain oil anyway.) If you don't want to change your oil filter as much, you have to get a filter thats made to filter for longer periods of time.
