best shifting rpms
on
best shifting rpms
i was reading about torque and hp on these 2 sites:
http://vettenet.org/torquehp.html
http://www.allpar.com/eek/hp-vs-torque.html
now i am really confused. i cant really explain it, but now i'm not sure what is the best time to shift. if u read it u will know what im talking about. i usually just go to 6000 or redline before i shift. just about everybody on this site has more driving experience than me, so i wanted to know the best time to shift in each gear in the Z. thanks.
Holly poop. That's some technical stuff!
I’ve read both of the articles that you posted before, and several others on torque, horsepower and shifting points for maximum acceleration. Drag race a hundred times, and you can “feel” when the car is no longer accelerating. Temperature, humidity and barometric pressure will vary the shift points. “Feeling” the shift points sounds about as valid as the butt dyno, but it works. It works because of practice, practice and practice some more.
More important than the shift points is where you come into the next gear. If you shift from second to third, for example, and the rpms drop to 2,500, you're in trouble. If the rpms drop to 4,000, then you're near the top of the torque curve. Each shift should put you near the top of the torque curve in the “next” gear.
When you get it right, you can run better than 13.70 seconds in a 350Z stock. And when you get it wrong, you’ll run 14.3 seconds as I have many times (I just don't post those time slips).
Happy racing.
on
Nice trap speed. That other guy has an awsome 60'. Man i wish i knew how to launch at the drag strip. I donno if i should drop the clutch at 2500 and floor the gas after that or feather the clutch in or what. I've never tried it.
on
these days, with the gas price...I shift mine right before it hits 3000rpm...
and i'm interested in hearing y'alls response to this:
on
Shift at redline...Nissan engineered the transmission gear spacing to provide maximum acceleration efficiency.
In stock trim, you can feel the engine power start to roll off towards redline, but the drivetrain is still providing more force to the wheels than it would in the next gear up.
MAsSIVrOOM
10-20-2023 10:50 AM
04-04-2016 07:52 AM
Justin100
11-29-2015 03:58 PM
