speed limiter removal
has ne one sucessfuly removed the speed limiter? haw hard is it to install the greddy limit remover? i need to remove it for an upcomming event
you can get a reflash to remove the rev limiter
I hope you mean the rev limiter and not the speed limiter...
The speed limiter is there for a reason and I would not disable it if I were you... |
It frightens me that you need this explained to you. No offense but this should be common sense at the very least. You can disable the rev limiter all you want and the very worst thing that will happen is a blown motor but the speed limiter is another matter entirely. The reason cars are speed limited from the factory is because when these cars are designed and engineered they also conduct extensive testing to determine the vehicles maximum safe speed. While the car may be capable of going a certain speed there is often a point where it becomes unsafe and once they determine what that maximum safe speed is they place a limiter there so that you do not exceed it by accident. The Z is no land speed record setter and would most likely be very unsafe at that high of speed without significant modifications to it's coefficient drag profile. Not to mention at that speed if anything goes wrong you are guaranteed to die and may even take a few other people out with you! Something like a pothole or deep crack in the road or perhaps some debris on the road or even a simple tire blowout would spell a death sentence for you. The room for error decreases in parallel with the increase of speed. Just because the car can go faster doesn't mean it can do it safely...
First of all, NO! This speed limiter of 155 is placed on vehicles that are brought into the US! The same vehicles in other countries use the same exact tires and have the same coefficient drag properties yet they dont have speed limiters. The government places these limiters to limit car crashes and deaths per year. Only an idiot will do high speeds on a pothole. The speed rating on a tire is totally different, some vehicles are equipped with Z rated tires and they still cannot exceed 155. The BMW m3 is capable of much higher speeds than 155mph, and also the BMW m5, and the supra twin turbo. Yet all these vehicles had the 155 mph speed limiter. You're telling me these cars cant do 155+ safely? Go back and do some research, then post. Thanks :D |
Could not have said it any better myself! Speed limiters are for Government purposes only... They are equiped on all cars made, and imported to the U.S. It is not that sports cars cannot do 155 safely, it is exactly like spratt said... Cars can handle much higher speeds however the U.S. feels that if they put speed limiters on our country can cut down of car fatalities.
Originally Posted by 97supratt
:icon18:
It sucks because we have to spend another 500+ dollars removing the damn limiters!
:icon18:
First of all, NO! This speed limiter of 155 is placed on vehicles that are brought into the US! The same vehicles in other countries use the same exact tires and have the same coefficient drag properties yet they dont have speed limiters. The government places these limiters to limit car crashes and deaths per year. Only an idiot will do high speeds on a pothole. The speed rating on a tire is totally different, some vehicles are equipped with Z rated tires and they still cannot exceed 155. The BMW m3 is capable of much higher speeds than 155mph, and also the BMW m5, and the supra twin turbo. Yet all these vehicles had the 155 mph speed limiter. You're telling me these cars cant do 155+ safely? Go back and do some research, then post. Thanks :D Now that I have cleared that up let me retype what I said previously in a format that will be a bit easier for your brain to digest. I did not say that it isn't capable of going faster than the limited 155MPH. What I did say is that it is not capable of doing it safely and that is why they limited it to 155MPH. Now, you do your research and then post. Thanks:D |
Double post...
Not to mention the fact that about 1% of civilian drivers even have the skill to handle a vehicle at speeds above 155MPH. If you ask me based on the average skill level of most American drivers it should be even lower than that...
i'd still take it off, just because you're capable of going over it doesn't mean you have to, i just don't like the idea of having something i paid for limited
why can't we just get along?
I'm sorry, but 97supratt is right, agreed!
You could not be more wrong my friend.....
Cars can safely go faster than the speed limit but can the average driver? Wouldn't that make much more sense, especially since most speed limiters are set at 155MPH. And the cars are WAY different. And what if you improve tires (wider), suspension, aerodynamics, ... on your car? Why wouldn't you be able to safely remove the speed limiter? Also, all the German cars have speed limiters in both Germany and the USA. But the German limiters are set higher. When I bought my Sierra Cosworth, the manager of the Ford dealership was a good friend of mine. I could choose between 2 "modules" for the car: the Belgian and the German one. The German one made more HP and had a higher speed-limit. When I asked my firiend about that he started laughing and said "you should see the US module", adding that it even had less power and lower speed-limiter than the Belgian one. Sometimes car makers put speed limiters in their cars to be able to use cheaper parts, a shrining example of this is Cadillac's use of a 112 mph speed limiter to compensate for a new automatic transmission that isn't up to the demands of higher speeds. And for those who want to remove the speed limiter, look HERE |
thezedsled: Let us not talk about brains digesting anything since yours is obviously having problems of its own.
You are arguing a moot point. It's obvious to everyone that speed limiters are for exactly what the name implies; TO LIMIT SPEED. The 350z without a speed&rev limiter would be drag limited, not gear limited, so there is no chance of blowing your motor. I have no idea where you pulled that idea from. Wait a second, yes I do. The same place your head is. I will also rebut another one of your failed arguments. The 155 limiter has nothing to do with extensive testing on a particular car. It's an agreement with manufacturers to limit speed to a common value, for several reasons... not simply because a particular car can't safely go faster. Another turd out of your mouth is about the coefficient of drag affecting safety. Where are you getting this crap? You are uneducated at best. The coefficient of drag by itself has absolutely NO impact on safety at high speeds. It doesn't matter if a car has a terrible cd, if it has a lack of lift and sufficient downforce it will be safe. You are also mistaken about the FORD GT. It is electronically limited to 205, not 255. What a joke. My question to the poster is, at which event do you plan on seeing 159 on the speedo? For some reason I'm not seeing that happen unless you have done modifications, which I doubt because if you had done modifications you probably would have removed the limiter already. The tires are the biggest safety issue with high speeds, but the stock tires are W rated which means they are rated up to 168 (actual speed) so you do have a little room for more speed on stock tires. Anyone who has hit the speed limiter before knows the Z is perfectly stable all the way up to the limiter. I'm not sure how the car would do with 10+ mph because I haven't done it but I wouldnt expect any catastrophic changes. It wouldn't be a bad idea to install a roll cage if you plan on seeing much of those speeds, though. |
