My 1st problem with the Z...wouldn't start
I was trying to start my car today, and it wouldn't start for some reason. It's not like the starters dead because it did make the ignition sound, somehow the engine wouldn't turn over. I have a JWT Popcharger so I went ahead and opened my hood to check it out. Nothing was wrong, the MAF sensor was plugged in, no visible leaks I could see...nothing. I went back and it started. This is the second time...any ideas? Happened to anyone? I only have about 3500miles on it.
My Z wouldn't start too, thought it was the battery, but realized later
that you need to press the clutch otherwise the car doesn't start :) Rookie error :icon38: |
i have 1082 miles on my new z and it happened to me yesterday. i went into a store came back out and tried 3 times to start it and it wouldnt. Made me look like ****, brand new car with paper plates and the ***** wouldnt start. I chilld there for a few mins and tried it again and it worked. Dont know what happened, but i have no mods all stock....
Try another key maybe its the code in teh key, but it wouldn't make since because you said it makes the ignition sound. The chip doesn't even let you get that far if its bad, I believe. How about the gas, give it some gas when starting or put some in if your low. check your battery cables as well.
Originally Posted by bugsbbunny
No, I don't think it's that...any other ideas???
always check the battery first, if you can jump start it then obviously thats your problem. don't assume its not the battery just b/c your have a "newer" vehicle. also check your batt cables as barthelb recommended.
I think there was a TSB or a RECALL on this problem. Check out www.nhtsa.gov see if this might help you out:fingersx:
immoboliser
It happened to my younger cousin he was taking the car to prom and picking up from my house but i left him the spare and what happens is that if the key is not an immoboliser key it will not start it and the spare was not immoboliser the computer will say wait a minute something aint right i cant read this key and it wont start just thought i would share that
Was there a recall on this problem? I don't think it's the key (code) because I could start it to the point where the ignition sound comes on, but the car just wouldn't turn over. This happened to me twice already...just trying to filter out what could be the problem. I'm going to check the battery cables today...thanks for the help, I will post a follow up in a little bit.
I have been having that problem for maybe 4 months on an 03 Touring with 16,000 miles on it. Whenever it happens if you just wait 5-10 seconds before turning it over it will always start. Talked to one other Z owner who experiences the same thing too. Read that recall it does sound like something similar to this.
Originally Posted by Kanyon71
I had this happen yesterday also I had like 1100 miles on my 06, was at Sports Authority girl and I come out get in the car it turns over like it's gonna start then doesn't. Had to turn the key off try again and on the third time I did it the car started. Was really weird, never had it happen before and hopefully it doesn't happen again.
I had a similar problem with my 00 maxima. Generally have to pull out the key until the digital odometer disappears (30 seconds) then try again and fires right up. Maybe some screwy reset issue with the computer. But whenever I had this similar problem, just waited and fired right up.
Could it be the crankshaft sensor messed up. mine was and i had lik 5000 miles on my Z. couldn't start my car for a while. could be that. check up @ nissan
| All times are GMT -8. The time now is 06:54 AM. |
