Rear differential dried oil stains
on
I'm considering buying a 2005 manual with the below pic of rear diff. How concerned should I be on a scale of 1 to 10??
Whats the best and worse case scenario of what could've caused those dried oil stains?
Thanks a bunch!
Thanks a bunch!
Looks like the oil from the rear diff bushing. Typically it runs down the rear subframe itself, not sure if it would also run down the diff but I couldn't see why not.
Pretty common thing on the Z. You will have to change out the bushing.
Also, it could possibly be from the breather hose but if I remember correctly, the breather hose is located to the right, not the left. So my money is on the rear diff bushing.
Looks like all that mess if the goo from the diff bushing. From that really bad picture
350Z/370Z Tech Moderator
Although how it got on the pumpkin itself is kind of mystery so this isn't definitive.
on
Nissan charges about $1400 to fix that since they won't simply replace the blown bushing, but charge for an entirely new subframe. If you buy this, you'll either need to do that or replace that with an OEM, polyurethane or an aluminum one and find a shop to replace it. May as well get the diff bushings replaced too while it's disassembled.
I'm guessing that's why he's selling it to avoid the hassle of doing this himself.
Ummm, yes, I've dropped oil on headers many a time. Heh heh. You try adjusting solid lifter tappets on a small block Chev without a specially cut up valve cover to keep the ooze off the exhaust.
jhc (10-25-2016)
Honestly, if that's the only issue with the car and the price is good I wouldn't let it deter you from purchasing it.
You can easily find a used diff for sale for cheap and it's not too bad to change the rear bushing.
I am putting my OEM VLSD for sale soon and also the diff bushing remover from Z1.
Can see oil on the rear cradle too, it's the bushing. Simple as mentioned above
on
Thanks for all the replies!
I've decided to pass on this particular Z but another question: on average, how many miles before major mechanical issues? 100k, 125k? (assuming it was not raced, beaten, not well maintained)
Impossible to say
Way too many factors
You can have a car with 200k run better than the same cars with 100k miles
Just remember, stuff like the diff, brakes, exhaust, etc can be changed with ease.
Most important things to look at, in my opinion, when it comes to looking at used cars...
The frame, accident history, electronics, engine, transmission, clutch, suspension, rust, etc.
I beat the crap out of mine and it's got 159k on it. Biggest major problem, diff bushing, Lca bushings and wheel bearings. Oh I did sheer the flywheel off the crank a while back.
on
Best to replace Flywheel with clutch??
So I actually got this Z last weekend! Seller came down the price of a new clutch and bushing install. Since money is tight on my end, how bad of an idea is it to keep the stock flywheel when replacing the clutch?
Thanks for all yalls help!!
Since it is being opened might as well change the flywheel since you don't know the condition that it's in.
6 inch cawk is my fave!
Take a picture of the bushing and post it up... It could be that someone tried to fill the differential through the vent tube and just over filled the **** out of it... I dont think the rear diff bushing has that much fluid in it, I could be wrong though. Mine didnt have any fluid in it when I cut it out of my subframe.
