Sponsored by:
Sponsored by:
Purchasing an 07' with 90k miles.
Old 06-19-2017, 06:15 PM
DerekA
DerekA's Avatar
Default Purchasing an 07' with 90k miles.
My dad is wanting to get rid of his Z (Enthusiast 07') mainly because he never drives it. My research has yielded some positive results on the longevity of the car. Although, I've read mixed things on the lifespan of the transmission. Hoping for some helpful insight from you knowledgeable folks that I should look for/into before buying.
I've been planning on buying a car in the near future but with this, I'm wondering if I should buy this instead...
Old 06-19-2017, 07:30 PM
rancor
rancor's Avatar
The transmissions in the 06-08 are just fine. You don't say if it's a manual or A/T though. Manual can(will) have slave cylinder issues so if you replace the clutch you should also replace the slave cylinder with an upgraded one. You might be close to a clutch anyways.
DerekA (06-20-2017)
Old 06-20-2017, 09:02 AM
DerekA
DerekA's Avatar
Appreciate your response. Ah, my apologies. It's an automatic (my dad's lazy). He bought the car pre-owned and maybe put 10k miles on it. As far as I know, no issues under the hood. The interior seems to be deteriorating a bit but that's not a big deal.
Old 06-20-2017, 09:10 AM
iideadeyeii
iideadeyeii's Avatar
I've NEVER heard about auto transmission problems on the Z except in high HP applications
Old 06-20-2017, 09:15 AM
DerekA
DerekA's Avatar
If I'm understanding correctly, as long as regular maintenance is maintained, this big beautiful beast should last for years/miles to come?
Anyone have any experience on using this car as a commuter car?
Old 06-20-2017, 09:23 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
i daily'd mine for 3 years.. no complaints
DerekA (06-20-2017)
Old 06-20-2017, 09:33 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
My pre-order '03 track Z is not a four season car here in Colorado. But it's been a reliable DD for 14 years outside of that. If you're purchasing an '07 from your dad, I can't think of a better situation for getting a serious performance machine...
DerekA (06-20-2017)
Old 06-20-2017, 10:03 AM
Atreyu'z 350
Atreyu'z 350's Avatar
I drive mine 128 miles a day 5, sometimes 6 days a week with no problems. I have an '05.
DerekA (06-20-2017)
Old 06-20-2017, 12:46 PM
DerekA
DerekA's Avatar
Oregon doesn't experience the seasons as heavily as Colorado may but, naturally, I would assume this car isn't fit for snow driving. I'll just have to use the wife's car during the winter . He's selling it for $9000 which doesn't seem too bad for near excellent condition. I appreciate your input, sir. Thanks!
Old 06-20-2017, 12:48 PM
DerekA
DerekA's Avatar
Default (Sorry for double posting)
That's inspiring to hear! How often do you do regular maintenance?
Old 06-20-2017, 02:24 PM
Atreyu'z 350
I follow the recommended intervals via the owners manual. 3,000 mile oil changes, regardless of me running synthetic or not. Air filter every 3rd oil change. Trans drain and fill every 15,000mi. Coolant flush once a year, maybe twice. I've only had the car for 18 months, so the regiment begins. Everything else I inspect frequently and repair or replace as needed.
Old 06-20-2017, 07:11 PM
Frostydc4
Frostydc4's Avatar
^^^what he said
You really have to try hard to blow these 5AT.
Old 06-20-2017, 11:55 PM
zwei_the_c
zwei_the_c's Avatar
Originally Posted by Frostydc4
I recall someone running a single-turbo on a Z33 5AT with no issues.
The AT are pretty cheap to replace considering nobody wants a 5AT if you blew yours. ha ha
Old 06-21-2017, 06:22 AM
dkmura
dkmura's Avatar
Not to take this too far off-topic, but at every Nissan Sport track day for years, the Zs with autos would overheat in short order. Although this was back in the day, the OEM automatic trannys didn't like shifting up and down that aggressively at higher speeds. These were all with unmodified VQ35DEs. Kinda frustrating when a 15-minute session became a 5-minute one when the trannys stopped shifting.
Old 06-21-2017, 08:25 AM
bboypuertoroc
bboypuertoroc's Avatar
Received 2,446 Likes on 1,768 Posts
I drove my Z in the snow with no issue. Just don't be a dumbass and you'll be fine.
Old 06-21-2017, 11:21 AM
HOMiEZ
HOMiEZ's Avatar
Early 2003 owner. 120k on the odo, daily driven and still on original clutch and no other maintenance on the tranny except for oil changes.
Old 06-21-2017, 11:36 AM
Swaglife81
Swaglife81's Avatar
Longetivity is the last thing to worry about on these cars. Nissan/Infiniti designed this car for dependability.
Bushings are about the only items that are really guaranteed to have some issues and that's not a big deal. The Throttle Bodies seem to be finicky with no average lifeline but that's about it besides normal wear and tear items
The​​ VQ is a proven 200K plus mile engine properly taken car of. A 07 with 90K miles my only concern would be old tires manufacturered over 6 years ago. Tire compound is done after 6 years.
Water Pump I've never heard of ever going out on these cars. My 03 has 208K on the clock and still gets amazing MPG and sounds/idles like new.
Old 06-21-2017, 12:51 PM
dynamic21
dynamic21's Avatar
I put 300,000+ miles on my 2003 as a daily driver in stop in go traffic + 300 miles every other weekend on the highway. That thing was bulletproof except for 3rd and 5th gear synchro grinding. I miss that thing, but it was due for new tires and the transmission was really bothering me so I sold it years ago.
I'm in a 2007 now with 130k on the odometer. It's used for daily driving and weekend cruising. So far, the two major things that have caused downtime was a cracked radiator and a slave cylinder issue (which you don't need to worry about with the AT obviously). Both issues were covered under warranty. These things are awesome, really. Key is to keep up the oil changes and maintain fluids - that's really all there is. There might be stupid little things that break here and there like door handles and plastic pieces, but those are minuscule in the grand scheme of things.
BjonesZ33
08-06-2017 01:03 PM
Silverbullet07
350Z Roadster
07-10-2017 12:38 PM
Rickdogg
05-04-2017 07:40 AM
bb17
04-18-2017 11:15 AM
Wabajack
04-15-2017 05:57 PM
Quick Reply: Purchasing an 07' with 90k miles.
