crash zone sensor resistance - MY350Z.COM - Nissan 350Z and 370Z Forum Discussion
Thread Tools Search this Thread
Old 08-02-2017, 05:39 AM   #1
zion2999
Default crash zone sensor resistance
can someone with a dmm measure the crash zone resistance for me? I have a 350z that has no airbags installed and I would like to get rid of the airbag light on the dash.
I have already placed resistors in the srs unit for the missing airbags but I havent been able to figure out the resistance for the crash zone, and it aint in the fsm.
zion2999 is offline   Reply With Quote
Old 08-02-2017, 08:47 AM   #2
bealljk
Can you be more specific on which sensor resistance you're looking for?
I can get you these from my (gutted) 03 touring
bealljk is offline   Reply With Quote
Old 08-02-2017, 10:11 AM   #3
zion2999
yes sure
Old 08-04-2017, 06:13 AM   #4
zion2999
bump
Old 08-04-2017, 07:35 AM   #5
bealljk
Quote:
Originally Posted by zion2999 View Post
bump
(been busy moving) but I still got you!
Old 08-05-2017, 09:03 PM   #6
bealljk
when I hook up a ohm meter it reads null ... meaning no electrical connection between the two wires -
Old 08-08-2017, 05:42 AM   #7
zion2999
thanks... confirming, this measurement is with the ign on or car started... right?
Old 08-09-2017, 12:55 PM   #8
bealljk
No - I took the sensor off the car and hooked up the ohm meter to the sensor away from the car.
Old 08-10-2017, 05:39 AM   #9
zion2999
thanks, I need the resistance with the sensor plugged in the car.
Old 08-10-2017, 06:59 AM   #10
dboyzalter
6 inch cawk is my fave!
Haha who is going to be the Ginny pig and mess with their perfectly good car just to get this reading?
dboyzalter is online now   Reply With Quote
Old 08-10-2017, 07:30 AM   #11
rancor
rancor's Avatar
Quote:
Woops airbags went off .
If this thing isn't showing a resistance when unhooked it likely won't when hooked up. You are also adding power to the air bag circuit when measuring resistance. That's probably not the best thing to try.
Better off to try and measure voltage across the sensor and current through it. I don't think this thing is a simple resistor though and I still think measuring this is a stupid endeavor.
rancor is offline   Reply With Quote
Old 08-10-2017, 08:17 AM   #12
karlt
It sounds like Zion2999 is trying to treat the sensor like an airbag. Airbags are passive; apply enough voltage and they explode. The crash zone sensor is active; it sends a signal to the airbag control unit under a specific set of circumstances. Unless you know how it works, trying to spoof the control unit may be futile.
karlt is offline   Reply With Quote
Old 08-10-2017, 10:49 AM   #13
zion2999
well, If its unsafe dont do it...
using google I was able to find the expected resistance for crash sensors for other makes. hence my hope that a similar solution would exist for my zed.
Old 08-10-2017, 10:52 AM   #14
zion2999
v=ir....
I googled the crash sensors, they all seemed pretty basic. some moving part breaks/opens the circuit when there is a collision and air bags deploy.
fact that the guy had no resistance in his, maybe his already triggered
Old 08-10-2017, 07:08 PM   #15
bealljk
v=ir....
Hey, anything is possible...I took all my airbags out with the exception of the steering wheel...
go luck with your setup though!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2017, MY350Z.COM All Rights Reserved.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
