Rear end feels loose/unstable going over bumps
Old 09-01-2017, 07:32 AM
Michael6593
Michael6593's Avatar
Default Rear end feels loose/unstable going over bumps
I've noticed that the rear end of my 350 feels loose/unstable when I go over bumps on the highway. It feels like the rear end kicks out and then it corrects itself. It also feels pretty bad on a bumpy road going 25-35 mph. The car feels stable on a smooth road, it doesn't seem to walk around at all. Any ideas of what might cause this?
Old 09-01-2017, 08:09 AM
iideadeyeii
iideadeyeii's Avatar
No, jack it up and look for bad bushings/anything that has play
Old 09-01-2017, 11:19 AM
WYZIWYG
WYZIWYG's Avatar
Rear subframe bushing probably needs to be replaced. If you see leaking black greasy stuff near it, that's probably it.
Plenty of threads out there already on what to buy and how to DIY if you're so inclined.
GL
Old 09-01-2017, 04:14 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,253 Likes on 2,314 Posts
Good suggestions thus far.
Would ask though, can you specify more details? Mileage, modifications to suspension, etc. Could simply be bad shocks, diff bushing, or in the case of something modified, improperly installed/torqued/or just came loose....
And that's relevant information that any/everyone asking for assistance should include in their posts for help.
Old 09-01-2017, 06:27 PM
Michael6593
124k miles. Completely stock. I did check the rear diff bushing and it does look blown.
Old 09-01-2017, 07:17 PM
MicVelo's Avatar
Shocks ever been changed? If not, they're about 75,000 miles overdue.
Old 09-01-2017, 07:28 PM
CK_32
CK_32's Avatar
Check your shocks and springs.
Check your bushings.
Check your axles.
Check your wheels and hubs.
Check your control arms.
Then your sway bar.
And check everything they touch or connect to. If you see oil, dirt, excess grease, charcoal looking piles. Something is blown, leaking or bad.
Old 09-01-2017, 11:27 PM
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Alignment , tire wear and shocks are what neould look at
Old 09-02-2017, 08:05 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Part out... How much for the lug nuts?
Old 09-03-2017, 03:54 PM
Michael6593
haha thanks for all the help guys. I'm definitely going to change out my rear diff bushing. Then im assuming the car is on the factory shocks... So im going to change those and then get an alignment. Im also pretty sure the front compression arm bushings are shot too. The car clicks/clunks when braking hard and when turning slow. Oh the joy of having a high mileage car.
Old 09-05-2017, 09:18 AM
iideadeyeii
124k miles is not high mileage
Old 09-05-2017, 09:37 AM
CK_32
CK_32's Avatar
While you do that tell them about your issue. Have them take a look if you are not competent enough to take a look for your self.
Hopefully they should be able to see underlining visual issues since they specialize with alignment and repair.
Old 09-28-2017, 08:30 PM
djnekkon
djnekkon's Avatar
after all these, all you'll be needing is a ****.....I kid I kid
