Enkei RS05RR (or rs05) brake clearance compared to TE37, LMGT4
Hey,
I'm trying to decide between TE37SL and RS05RR for my track 350z.
Because I've a pretty big brake kit (378mm) I`d like to know if the RS05RR (or rs05 should be the same)
have enough brake clearance. The wheels would be 18*10.5 +15.
Here are some pics of my brake kit with 18*9,5 +22 Nismo LMGT4 wheels.
I guess that the TE37SL should have similar brake clearance and that the brake should fit there.
These are the biggest brakes I could find behind these wheels:
Problem solved, I contacted Enkei and had to send them measurements of my brake system. They told me that I`ve 17mm space between the caliper and the spokes and 8mm at the top (for the 18*10.5 +15), That means that the rs05rr have very good brake clearance.
How did it work out for you? I went with 10. 22+ at front. my supplier forgot to specify the brembos, so I had to add a 10mm spacers to take to 12+ et. at the end had to cambered the front almost -2 with a 275/10 tire.
I didn't buy these wheels. But my brake system would have fit easily without any spacers, because my calipers are further away from the center than the stock brembos and the 10.5" +15 are very concave I'd have no problem.
djnekkon (05-09-2021)
thmotorsports
10-08-2013 02:18 PM
Get Your Wheels
10-02-2013 08:00 AM
Get Your Wheels
Vendor Group Buys
09-24-2013 01:22 PM
