Viagra For Oil Filters
I believe I found the biggest oil filter humanly possible for the Z.
Bigger filter = more oil capacity, better oil cooling, and helps reduce oil pressure drop over time (due to the tiny stock filter getting clogged).
K&N HP1008 (normal filter for a z)
Height 2.8"
OD 2.688"
Micron 10
PSI Bypass 11-17
GPM 10
Wix 51347 / Napa Gold 1347
Height 4.8"
OD 2.921"
Micron 21
PSI Bypass 8-11
GPM 9-11
BUY HERE:
https://www.oreillyauto.com/detail/b/wix-5291/filters-16470/oil-filter-16731/oil-filter-12090/556b119b1c85/wix-oil-filter/51347/4835684
https://www.napaonline.com/en/p/FIL1347
Baldwin BT40034
Height 5.5"
OD 2.626
Micron 23
PSI Bypass 14
GPM 11-15
BUY HERE: https://www.grainger.com/product/BAL...Element-52ZK04
Can you find a bigger one?! Please do!
For the money, the best option is to go with the Napa Gold 1347. It's the cheapest and still offers a significant increase over stock. Scroll down to see my testing.
Height 2.8"
OD 2.688"
Micron 10
PSI Bypass 11-17
GPM 10
Height 4.8"
OD 2.921"
Micron 21
PSI Bypass 8-11
GPM 9-11
BUY HERE:
Baldwin BT40034
Height 5.5"
OD 2.626
Micron 23
PSI Bypass 14
GPM 11-15
I like what Kev did but it's probably overkill* if youre running your car in normal conditions and getting regular oil changes.
Hey Kevin - where do you buy these and how much do they cost?
Id be interested to see what the filter element looks like...
*says the guy who runs two oil filters...
this is what i was able to find. pretty pricey. i will stick with OEM filters for my normal driving.
https://www.ebay.com/p/Baldwin-Filte...34/17005673673
I spoke with one of the engineers at Baldwin and he said it has metal end caps and the bypass valve is at the front, not at the rear. (all good news). I'm curious though so I'll cut one open after a few drift events to find out.
It costs $15.05. Almost twice the price as the Wix 51347 / Napa Gold 1347.
Apparently there are fakes...so I bought it directly from Grainger (free shipping to their store).
When i get to the shop today I'll fill it up with oil and see how much extra it holds over the stock filter.
$15/$20 isnt bad for peace of mind ... let us know what you find!!
The following 2 users liked this post by Kevin Skene:
bealljk (05-12-2018),
BluestreamDE (05-13-2018)
nice analysis ...
your oil looks like an IPA ...
Atreyu'z 350 (05-13-2018)
With so much more filter element surface area, you will see less pressure drop over time using the largest filter you found. Especially comparing to a 10 micron+tiny element K&N filter. That is more important than the volume of oil it adds to the system. I would run it
Kevin Skene (05-14-2018)
mike952
08-29-2002 11:07 AM
