Sponsored by:
Sponsored by:
03 350z touring no start, fuel pump good
Old 05-15-2018, 02:18 PM
Njohnson2294
Njohnson2294's Avatar
Default 03 350z touring no start, fuel pump good
I was hoping someone could help me out. I have a 03 350z touring. It currently cranks but will not start. Getting spark, and fuel pump is good and working, but will not start. I can only get it to start and run shortly with starting fluid, but once I cut the fluid it dies back out. Anyone have this problem before or can shed some light in the situation? Any help is much appreciated.
Old 05-15-2018, 10:15 PM
Kevin Skene
Kevin Skene's Avatar
Codes? Done any work on it recently?
Old 05-16-2018, 04:09 PM
Njohnson2294
Default No start
Only body work. Throwing a P1615 code.
Old 05-16-2018, 04:13 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Did you run out of gas?
If it starts with starting fluid, its not getting gas injected into the cylinders.
Old 05-16-2018, 04:20 PM
tmdz
tmdz's Avatar
P1615 NISSAN - NVIS Difference of Key
Possible causes
  • Faulty or not programmed ignition key
  • Faulty IMMU
  • Faulty Engine Control Module (ECM)
What does this mean?
Tech notes
This code is usually triggered when a not registered or damaged key is used to start the engine. When the starting operation is carried out five or more times consecutively with the same unregistered key, the system will lock.
If the problem occurs try disconnecting the car battery for about 30 minutes and then try starting the engine with a known registered key. If the problem persists you have to have the dealer erase the code and reprogram the keys again.
When is the code detected?
IMMU can receive the key ID signal but the result of ID verification between key ID and IMMU is not good.
Possible symptoms
  • Engine Light ON (or Service Engine Soon Warning Light)
  • Engine would not start
P1615 Nissan Description
An immobilizer is an electronic device fitted to an automobile which prevents the engine from running unless the correct key is present. This prevents the car from being hotwired after entry has been achieved.
The microcircuit inside the key is activated by a small electromagnetic field which induces current to flow inside the key body, which in turn broadcasts a unique binary code which is read by the automobile's Engine Control Module (ECM). When the ECM determines that the coded key is both current and valid, the ECM activates the fuel-injection sequence.
The immobilizer function of the Infiniti Vehicle Immobilizer System (IVIS) or Nissan Anti-Theft System (NATS) consists of the following:
- NATS ignition key
- NATS antenna amp. located in the ignition key cylinder
- Body control module (BCM) or (IMMU)
- Engine Control Module (ECM)
- Security indicator lamp
tmdz
tmdz's Avatar
Double post - My phone hates this site.
Old 05-17-2018, 05:11 AM
Dr. Venture
Dr. Venture's Avatar
I would have said bad Cam Sensor/s but if you get this code it's the KEY losing communication and the vehicle assuming it's being robbed.....Shutting down Fuel. Perform "key reprogramming"
Unforn unlike the FOb there is no way to program w/o the use of a scan tool.
Old 06-30-2018, 11:03 PM
Micheal Wilds
Micheal Wilds's Avatar
Thanking maybe im having this problem but im not throwing any codes yet, mines just cranks and cranks guessing maybe my injectors quit?
ccchaorule
01-09-2012 09:23 AM
Chris@DW
06-14-2011 09:11 AM
Quick Reply: 03 350z touring no start, fuel pump good
