Sponsored by:
Sponsored by:
Engine upgrades/other advice needed
Old 05-21-2018, 09:58 PM
StephenM57
StephenM57's Avatar
Unhappy Engine upgrades/other advice needed
Deleted post
Last edited by StephenM57; 11-02-2020 at 03:11 PM. Reason: Didnt explain everything well enough, because a total mess
Old 05-22-2018, 05:56 AM
LexD
LexD's Avatar
If you rear-ended someone hard enough to damage your engine I'd say you most likely damaged lots of other stuff too.
In short, no - forget about upgrades. Focus on getting it running, and driving straight again. In your position you should be happy if you ever get to drive the car again.
Old 05-22-2018, 06:09 AM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Originally Posted by StephenM57
because some d*ckhead purposely tried to cause a crash because he saw a teenage white boy driving a nice car, and assumed my parents got it for me(which he made obvious later by the comments he made after the crash)...
First off - stop being a victim and sack-up ... being a crybaby puss will get you A. no where in life and B. 3 post on this forum, you'll call everyone a$$holes and then leave (which is fine by us).
Anyways the crash caused engine damage, and cracked the cover to the timing chain, and now the crank will only turn 180 degrees so obviously some internal damage has happened. Took it to a mechanic, and he said i probably cracked a rod which i highly doubt dude just sounded like he was trying to get me to pay him to engine swap.
If you rear-ended someone, that's YOUR fault, not theirs ... you shouldn't have been driving so close or so fast that you couldn't stop YOUR car...
If you hit someone hard enough to crack your timing chain case and cause internal damage than you were driving WAY too fast and not giving yourself enough room to stop ... this is on you - not the dude you hit.
You've got insurance right? File a claim with insurance and be done with it.
I was wondering if there are any semi cheap upgrades (around 500ish and under just to add a little torque/horsepower)
There is nothing cheap and easy about 500hp ... a legitiment 500hp engine will cost you $15k by the time your done with internals, fuel, FI, ECU, cooling, etc.
if you want 500hp easy and cheap, find a civic
Your best bet will be to find a salvaged car and swap engines with an otherwise OEM engine.
Old 05-22-2018, 08:11 AM
iideadeyeii
iideadeyeii's Avatar
This is why I have dash cams in my cars, but the Z is the fastest stopping car I've owned (non-bremo brakes on mine)So, I couldn't see someone out braking me that's been in my lane unless they merged into my lane and then slammed on their brakes, but only half of their car made it into my lane(if that makes sense)
^^^ I think they mean $500 not 500hp ^^^ I thought the same thing at first
Old 05-22-2018, 09:17 AM
SpartaEvolution
SpartaEvolution's Avatar
I think OP meant $500, not 500hp. I'm not familiar with the HR motors, but I think the standard advice (plenum spacer) still makes power on the HR motor for less than $500 EDIT: Nevermind, HR has the new plenum design, I thought that started with the VQ37.. Having said that, if you're looking to replace internals to make more power.. it'll cost more than $500 for noticeable gains. Otherwise I completely agree, OP needs to take responsibility for his actions.
OP. we were all stupid teenagers at one point, we've all made mistakes, and we've all tried to make excuses as to why they weren't our fault. That's why your BS story is so easy to see through. If you were following the guy at a safe distance, you wouldn't have wrecked your car, or at least you wouldn't have hit the guy hard enough to damage the block (which, being a front-midship, is actually pretty hard to do). Furthermore, if you could tell that he was looking at you, and for whatever reason he "purposely tried to cause a crash because he saw a teenage white boy driving a nice car", then you should have been more attentive and maybe not driven 70mph behind the guy.
It's unfortunate that you had to learn this lesson the hard way, but it would benefit you to learn from it, and to be more attentive to the cars around you. Maybe convince your parents to pay for a defensive driving class at your local road course!
Last edited by SpartaEvolution; 05-22-2018 at 09:20 AM. Reason: google dropped some knowledge on me
Old 05-22-2018, 01:32 PM
samsniss350z
samsniss350z's Avatar
There are two things that just don't go together, they are: semi cheap upgrades and a Nissan 350Z.
Old 05-22-2018, 02:48 PM
bealljk
bealljk's Avatar
gd, I hope so...
Old 05-22-2018, 06:45 PM
Gs_350z
Gs_350z's Avatar
Forget about the upgrades. You might need that $500 for incidentals to get the engine back to OE spec. Nothing wrong with a NA HR Z. Be safe and learn to anticipate the unexpected. I do and I even drive with the headlights on 24/7......
Old 05-23-2018, 10:27 AM
StephenM57
StephenM57's Avatar
You don't know my full situation. You weren't there so you cant say ****, get off my post if all you're going to do is ***** around. No i wasn't speeding, no i wasn't close to him. I was driving normally. i had warped rotors, and was saving up to fix them so the car didn't break anywhere close to as good as stock. Also i meant costs around 500 not 500 HP. Also no, i didnt even hit him THAT hard, he had a tow hitch which directly hit my engine, and the top of the radiator. So before assuming maybe you should ask instead of being a ********
Old 05-23-2018, 10:28 AM
StephenM57
StephenM57's Avatar
I had warped rotors, made the braking not even close to as good as stock, and the dude had huge rotors, and some nice brakes on.
Old 05-23-2018, 10:33 AM
StephenM57
StephenM57's Avatar
I had warped rotors, so my breaking wasn't even close to as good as stock, and when i saw the way he was acting i was going to switch lanes, but someone boxed me in and i had good distance but i had someone riding my *** so i couldn't have been as far as i had liked with the way he was acting.
Old 05-23-2018, 01:05 PM
bealljk
bealljk's Avatar
You don't know my full situation...
All I can say is good luck with life - reality on reality's terms...
i had warped rotors
so YOU rear-ended this guy, driving at a legal speed, with ample stopping distance, not distracted because of warped rotors ... ok man, sure!
so the hitch went through your bumper/structural bumper/condenser/radiator/fans/shroud and then proceeded to crack your timing chain case & damage engine internals to the point where the engine wont crank?
How fast were you driving? and you had ample stopping distance? and you had enough reaction time? and this is all bc of warped rotors....rrrrriiiiiiiggghhhhttttttt...
terrasmak (05-26-2018)
Old 05-23-2018, 03:18 PM
SpartaEvolution
First off - stop being a victim and sack-up ... being a crybaby puss will get you .... post on this forum, you'll call everyone a$$holes and then leave (which is fine by us).
You called it man hahahaha
Old 05-23-2018, 04:29 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Ummmmm you don't know the situation, the op was driving with faulty brakes he was saving up to get fixed so it wasn't his fault at all...
Was 90% the other guys fault
And 10% the cars fault
In other news...
if you can guess what I would like pictures of you win a gold star
Old 05-23-2018, 04:31 PM
bealljk
bealljk's Avatar
omg, I see the light!!!
Old 05-23-2018, 05:44 PM
dboyzalter
dboyzalter's Avatar
Old 05-23-2018, 06:24 PM
StephenM57
StephenM57's Avatar
Wink
deleted
Old 05-23-2018, 06:28 PM
StephenM57
StephenM57's Avatar
Either try to be semi helpful, and not a total d*ck for no reason, or stop replying
Old 05-23-2018, 07:29 PM
dboyzalter
dboyzalter's Avatar
warped rotors still brake decently, point is not as good as stock, but good job on trying to be funny ;*
better?
Old 05-23-2018, 11:40 PM
bad boyz
bad boyz's Avatar
You just walked into a hornet's nest best to access the damage by your insurance carrier total it and start from scratch,seems like the damage was pretty serious to damage a crankcase regardless how it was damaged,your story just doesn't hold much water so just take inconsideration your talking to car people with a lot of experience,so just embrace the wisdom and come correct if you want some good advice!!
Quick Reply: Engine upgrades/other advice needed
