Sponsored by:
Sponsored by:
350z motor noise problem metal on metal
Old 07-15-2018, 08:00 PM
Shayne Bryan
Shayne Bryan's Avatar
Default 350z motor noise problem metal on metal
My engine makes a really awful sound and i have been researching and theres no video of this happening in any other Z that i could find so wanted to know if this is fixable or if i should just swap a new engine in its an 06 rev up engine
Old 07-15-2018, 08:17 PM
Kevin Skene
Kevin Skene's Avatar
Jesus
Old 07-16-2018, 09:20 AM
KornerCarver
KornerCarver's Avatar
It sounds like your bearings are toast. You can get it repaired or get a used engine. I suspect you ran it out of oil.
Old 07-16-2018, 10:45 AM
tmdz
tmdz's Avatar
I'd check all the pulleys - It sounds like you lost a couple bolts and one of them is slapping back and forth as the belt is driving it.
Old 07-16-2018, 11:15 AM
travlee
Master
travlee's Avatar
Received 9,047 Likes on 6,513 Posts
your engine
Old 07-16-2018, 11:34 PM
Faasnu
Faasnu's Avatar
Why does your oil temp gauge go all the way to hot?
Old 07-26-2018, 12:03 PM
ajpasa
ajpasa's Avatar
Have you checked all the basics? I mean:
1. Fluids
2. External loosen parts, including pulleys
3. Belts
4. Then engine mounts, transmission connection
After all that, you have to go inside the engine
Br,
Al
Old 08-02-2018, 06:09 PM
Bernardo Z33
Bernardo Z33's Avatar
Originally Posted by Shayne Bryan
https://youtu.be/cKx8Z0SDkaw My engine makes a really awful sound and i have been researching and theres no video of this happening in any other Z that i could find so wanted to know if this is fixable or if i should just swap a new engine in its an 06 rev up engine
DUDE look at your temp gauge for christ sakes. Wouldn't that be a sign? Maybe one of the chains controlling the water pump snapped and thats whats causing all of the noise.
PNW_Chief
04-11-2014 07:28 PM
Lambo88
12-27-2012 02:56 PM
Rekinyze
01-15-2010 04:59 AM
dskang100
05-10-2005 10:45 AM
Quick Reply: 350z motor noise problem metal on metal
