Illuminated NATS antenna swap
Old 10-03-2018, 06:30 AM
DeusExMaxima
Recieved 10 Likes on 10 Posts
Default Illuminated NATS antenna swap
The 2008 350Z was the first year to have an illuminated ignition switch ring. I have a 2005 car. I bought a 2008 ignition switch and would like to install the illumination ring. Is there any way to install the ring and keep my original NATS antenna or can I install the 2008 antenna and lighted ring without having to reprogram?
DeusExMaxima is offline
Old 10-04-2018, 05:31 AM
Heel Til I Die
Recieved 173 Likes on 124 Posts
Check out this thread: https://my350z.com/forum/exterior-an...ition-cyl.html
You can trim the outside of the ignition ring and slide the illuminated section over it. You can then wire it up to the courtesy/dome light.
Heel Til I Die is offline
Old 10-04-2018, 12:36 PM
DeusExMaxima
I saw that thread but I don't think it mention anyone who actually trimmed the ring and slid the illuminated part in. It did however show that a G35 illuminated ring fits over the outside of the NATS ring.
I found a 2008 ignition switch online, so I ordered it and it is presently on its way. I will update this thread as I make progress.
Old 10-05-2018, 11:43 PM
bad boyz
bad boyz's Avatar
Recieved 21 Likes on 19 Posts
I have a 2006 and it has illuminated ignition switch ring?
bad boyz is offline
Dave Curry (10-09-2018)
Old 10-06-2018, 08:50 PM
DeusExMaxima
It does? I guess they put them in 06's and up..
I received the 08 ignition switch but the seller did not include the bulb or the wiring. I went to the junkyard and decided to use the illumination ring that goes on the outside of the n a t s antenna. This is found on Altima and Maximas. The one I got was from a 2002 Altima. It had the bulb and the wiring. It seemed easier to install and I was right because when I brought it home I just had to grind a small amount off the plastic and it fit perfect. Also the trim piece which goes around the turn signals and windshield wiper stops has an opening that's just large enough for the ring and so I didn't need to use the little trim ring that goes around the outside. I'll post pictures tomorrow
Old 10-07-2018, 07:35 AM
DeusExMaxima
The illuminated ignition switch works great and I used my original NATS antenna so I do not need to program my keys to start the car.
Old 10-09-2018, 07:10 AM
Dave Curry
Dave Curry's Avatar
Recieved 0 Likes on 0 Posts
Well, I bought my 06 Z last year and I was like..wait a minute mine has a light up ring. So 06 and up I think
06 Illuminated Ignition ring
Dave Curry is offline
Old 10-09-2018, 08:25 AM
DeusExMaxima
I'm curious if the black NATS antenna is changed, if the ECU/BCM needs to be reprogrammed. If its just an antenna, it would not need to be reprogrammed
nachospizza
03-08-2012 05:41 AM
solidfish
06-08-2010 08:49 AM
MySunset350Z
12-12-2005 01:59 PM
MySunset350Z
12-02-2005 01:47 AM
Quick Reply: Illuminated NATS antenna swap
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
