Clutch pedal Teflon “spacer”
I have a 2006 350 Z all original clutch while I was adjusting the push rod in side the car from the pedal to the master cylinder I lost the little Teflon spacer that goes on the pin that connects the pedal to the pushrod Does anyone know where I can get one Thx |
I dont have one but here is the Nissan OEM part number for the clutch stopper 46584-S0100
Sounds like you're talking about the Clevis Pin assembly that attaches the master cylinder push-rod to the clutch pedal. I did some parts digging and unfortunately it doesn't appear to be sold individually or as a kit. As a temporary measure I would recommend taking a trip to the local hardware store and finding a washer that closely matches to the original. But a better and more permanent solution would be replacing the horrible OEM clutch pedal with an RJM performance unit. The RJM kit includes a higher quality push-rod fork and more heavy duty clevis pin assembly. Money well spent once you feel the difference.
Good Luck! -Icer |
