Back in a Z again.
Hey folks. I just picked up a clean 03 Z. Has a bunch of stuff done to it. For starters it has coil over adjustable struts. I want to ask what the expectation is. The car is really bouncy. Feels like I’m rolling a juiced 64 impala. Plus when I go I’ve an over pass I get flash backs of the Duke boys. Seems odd. Also the driver side seat back will not adjust up... only back? And the headlights need to be aimed. They are crazy non existent. Must be shooting light into outer space. It’s good to have a Z again. I need help remembering how to work on them. feeling like I’ll find more. Anyone able to help me get started? |
Post pics |
Hi, depending on the coilovers, you may have an adjustment screw on them, for softer or stiffer ride. Depending on how low the car is, you may also have no suspension travel, aka, jarring ride quality.
For headlights, this guide is really good: http://www.hypersprite.com/auto/tech-z-003/index.asp You will need an 8 inch #2 Phillip's screw driver. As for the seat, I suggest looking at the mechanisms and try to figure out if there is an issue. Make sure to search if you have any specific questions, theres a good chance the answers are already posted. |
Thanks guys. And I’m trying to get the hang of searching. It’s been a while. They look like Tein Struts. The car is so low I can’t really see anything. But I’ll work on that. Here are a few pics https://cimg0.ibsrv.net/gimg/my350z....80b149faa.jpeg https://cimg2.ibsrv.net/gimg/my350z....354bec6de.jpeg https://cimg1.ibsrv.net/gimg/my350z....4fd1f252a.jpeg https://cimg3.ibsrv.net/gimg/my350z....9fbcbcc7c.jpeg https://cimg4.ibsrv.net/gimg/my350z....389c1de75.jpeg |
Tein Flex.. I’m trying to see if I can tell if there installed right. The back looks odd. https://cimg7.ibsrv.net/gimg/my350z....eb7c3bb776.png |
The car looks good, has definitely been modified a bit, but clean looking. The top hat of the coilover (in your engine bay pic), looks like there is an adjustment knob there. It could be set too soft causing the bouncy ride, or perhaps your shocks are blown. I don't have experience with those coilovers, but from my research, they should be a stiff ride, but not bouncy as you explained.
Hard to tell from the pictures, but the rear looks like you have a spring with an adjustable seat in your spring bucket. You can raise or lower the car by adjusting the spring seat. I would suggest taking the wheels off and giving all the suspension components a thorough inspection, if you're unsure of how it was installed. Also I usually search with google this way: "(what you want to look for) site:my350z.com" |
Start readjusting the coilovers, most likely they adjustments are screwed. |
I’ve been reading all weekend. I wish I had the install manual for the kit “tein control master type flex 350z” but I can’t find it... going to try and send Tein an email. Based on all the installs I see the rear of my setup is upside down and the adjusters and rubber spring isolator is missing. I can pull it apart and remove the upper spring isolator and reinall them right side up... but need parts I guess... he may have included the adjusters, need to look in the box... but I don’t think I have the rubber isolator. It looks great as is but I can’t get in or out of my driveway so I’ll need to lift it just enough so I can. I’ll go try the adjusters today thoughts on the rear install? |
I did find this one: One more question. Will the stock engine cover work with this setup or do I need an aftermarket one? https://www.z1motorsports.com/engine...er-p-3347.html https://cimg9.ibsrv.net/gimg/my350z....7a9169fe2.jpeg |
I've had a good amount of experience with coilovers and they should not be bouncy. There are a few things it could be, the first I would check since it's the easiest is what a previous person said, check the dampening if they have it. By the looks of the pic they might not. The second thing would be to check the springs pre-load, for this you would have to take them off the car. The last thing is like the others have said, could be a blown coil. I would be willing to bet that it's most likely the pre-load since hardly any novice DIY mechanic knows to set that up correctly. If you need a walk through message me!
thank you fiddy_sent! I did pull them apart yesterday and found a few things incorrect. Tein sent me the flex install manual and I just reset them up. The front was set to 0 for the damper and the rear was on 4 or 5. I adjusted the coil to the recommended starting point, 1.0 inch. The rear the shock was never turned down from factory height, so I set it to the recommended setting and the coil spring was upside down with no adjusters... I flipped it around and put the adjusters back on (they were in a bag luckily). I did raise the car as well which is what I was after since my driveway was killing the car, now its OK, I may even be able to drop it down a bit more (spring time fun). I had to order some spanner wrenches so I could torque the settings (Tein Spanner has a hole for he torque wrench) once I have them tight I will have the alignment checked and corrected as needed. I had to drill out the small hole on the rear strut tower so I could get a wrench down to the damper... I am looking for a nice cap to use for the hole... but my starting point (per the manual) will be 8 on the damper... so I will see I guess... Thinking with the front so low (it was like an inch from the ground) and set to 0 on the damper its what was making it so ruff... ill know more after I get it tight... I dont want to drive it till I am able to torque it up... I only have the one spanner and I used a screw driver to tighten it some (looks like someone already did that :( )
thank you for responding.. this forum is not as active as I was hoping... it since that you mentioned some ideas. |
Stock engine cover will not work with the Kinetix plenum without a good amount of trimming. The only cover I'm aware of that will fit the Kinetix plenum is the Kinetix cover you linked from Z1.
Thanks I just ordered one. |
Originally Posted by myrddin
(Post 10975061)
thank you for responding.. this forum is not as active as I was hoping... it since that you mentioned some ideas. Oh sweet i'm glad you're getting it all sorted out. Sounds like the previous owner was doing some crazy stuff when installing them....lol Yeah i've been a bit disappointed too, I have a subie also and have been apart of the nasioc forum for a long time so i'm used to a super active community. |
