knocking out Cats
Not the furry kind but the ones on your car. I was considering pulling the cats down and knocking them out in lieu of test pips. I did this with some other cars but wasn't sure it it's worth it over buying used test pipes or ebay specials for 80 bucks.
Originally Posted by Franknbeans
(Post 10982346)
If it were my money, I'd buy them online at that price. You'll save a lot of effort and can always go back. If you're happy, sell the cats, they usually bring $100 and up. GL! |
Theres no sniffer test up here, but a visual to see if the cats are still there. Thought about test pipes with a rezanator... it kind of looks like a cat. Might be able to sell it off as a high flow cat.
I have resonated test pipes. Unresonated don't sound as great. If I recall correctly, there is aluminum shielding around the stock cats. If you're worried about a visual inspection, maybe you could put the shielding from the stock cats around the new test pipes.
Just gut them.
As jhc mentioned, if you gut them you are going to get a CEL for the downstream O2 sensors (hence the no fouler fix). You may not get the sniffer test where you live, but do they scan your ECM? Also, driving the Z with a CEL for the O2 sensors will cause the engine to run poorly. I would personally recommend not bothering with the hassle of gutting OEM cats since they are valuable part (assuming they still function). I would personally use resonated pipes like the Motordyne ART.
-Icer |
Why? If you're chasing power, test pipes are a drop in a swimming pool of money.
Originally Posted by munkeymike
(Post 10982441)
If i go with test pipes that everyone is recommending. Should I stay away from ones with flex joints. Especially, cheap ones?
I read these blow out easily. |
Knocking out the cats causes turbulence, tests have shown less power by doing this. Just buy a test pipe |
got a lead on lead on used ARK test pipes for 200ish.
The y-pipe has flex joint sections, so you don't need them on the cat/test pipe
If you can find used Motordyne ART pipes for $200 that’s a pretty good deal but you can get new resonated Berk test pipes off of Ebay for about $250 shipped. Either way just be sure to do your research. Some say not to use impact tools as they can f-up your O2 sensors and you will need a mess of 1/2” extensions to get to the demon bolts. Cats on the 350z can be brutal to remove. |
Yeah man, the ARK pipes fell through. Someone else beat me to it.
I've been watching a couple vids on how to remove them and seen the huge extensions that you need to get those bolts from the top. |
(Post 10982573)
Taking the advice of just getting the Test Pipes. I'm gonna order these one form amazon. Should I pick up the O2 foulers also? I plan on a tune, but unsure when it will happen. Might drive it around for a month or two before the tune happens.
The O2 fouler fix is hit or miss depending on year model. Even then, I cant tell if the bung on those pipes are extended enough for that to work.
If you're going to get tuned, I'd say dont bother with the foulers, the tuner can just turn that code off. You may run slightly leaner, but it's nothing to worry about. Also, I would reccomend doing all the mods you want to, prior to the tune. |
