Help: Flywheel bolts to short
Changing out clutch pp anf flywheel. Upgrading to a stage three clutch. I bought a kit and the bolts are not long enough because the flywheel is thicker.
Is this common? Do they sell a bolt kit? Ive tried local hardware stores and fastenal and have had no luck thanks in advance |
Originally Posted by Stuartm77
(Post 10992144)
You will (likely) need OEM star / torx bolts - M10 x 1.0. I could not find them anywhere and Nissan had to order them in. I ended up using the bolts I took out. I ordered the the ARP bolts and they were incompatible with the JWT flywheel as were the OEM automatic transmission bolts. |
Originally Posted by bealljk
(Post 10992149)
which clutch are you going with?
You will (likely) need OEM star / torx bolts - M10 x 1.0. I could not find them anywhere and Nissan had to order them in. I ended up using the bolts I took out. I ordered the the ARP bolts and they were incompatible with the JWT flywheel as were the OEM automatic transmission bolts. The bolts im using are off manual transmission/flywheel but only stick through the flywheel about 1/4” |
(Post 10992153)
Thank you for reply. I have the oem bolts however they are too short. I need them to be 1/4”-1/2” longer than oem. Didnt know where to get them
Did the flywheel and clutch kit come as a combo unit? Or are you trying to mix and match? You need to be very careful about this since not all aftermarket flywheels will work with all aftermarket clutches.
-Icer |
Also - are you installing the flywheel with the cranks pin and flywheels corresponding mating hole lined up?
If OEM is too short look into Fastenall ... they had M10 x 1.0 at different lengths but they had to order them in and I didnt want to wait. post up some pictures |
Originally Posted by icer5160
(Post 10992182)
-Icer As beal said, make sure you properly align the tiny hole in the flywheel with the dowel pin on the crank. Failure to do so will cause massive problems! -Icer |
