Sponsored by:
Sponsored by:
350z died and now wont start
Old 06-15-2019, 03:37 PM
Gm_media
Gm_media's Avatar
Default 350z died and now wont start
Hi guys i have a 2003 nissian 350z on my way home it starts skipping like coming in and out of power it gets worse the more i drive as im creeping it up my drive way it stalls out staying around 400 to 500 rpms any throttle chokes it even more 10 second later it dies . Wont start after that . Thought it may be battery lead cause it broke on me before and did the same thing but take the battery cover and all is fine i checked to make sure it wasnt broken or loose . Then i thought might be maf came unplugged so i umplgged it and plug it back in . Still didnt help. Now thinking it might have jumped timing ? Or s sensor went out any one else have tgis problem if so whats the fix?
Old 06-15-2019, 04:14 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
Did you pull codes?
Old 06-15-2019, 05:01 PM
Gm_media
Gm_media's Avatar
No codes figured it out fuel pump will prime but will not keep enough fuel pressure to keep it running . I tested it by removing the air filter and using a spray bottle to spray fuel in as someone else turned it over and it crank an ran no problem until i stoped and it would slowly die. But problem solved a 150 fuel pump so glad the ecu thing had me worried.
khnitz (06-19-2019)
Old 06-15-2019, 06:51 PM
MicVelo's Avatar
Great, thanks for following up with the solution so others may benefit from your experience! (Not enough people do this!)
khnitz (06-19-2019)
zownz
06-24-2019 04:10 PM
Lui
06-08-2018 07:19 AM
boostintt
10-16-2012 05:07 PM
Nismomonkey
07-25-2012 02:06 PM
myclean350z
12-24-2010 10:18 PM
Quick Reply: 350z died and now wont start
