Sponsored by:
Sponsored by:
Dash lights and radio not working!! HELP!!!!!
Old 07-19-2019, 08:07 PM
Cosmic z
Cosmic z's Avatar
Default Dash lights and radio not working!! HELP!!!!!
I was driving and I went to turn into gas station and my gf seat moved forward and immediately the radio and dash lights cut off I check the fuses and found that the mirror fuse was indeed blown! I replaced the fused turned the car on and they worked for like 1 sec then it popped the fuse I tried it one more time and it did it again any sides what could cause this, wondering if it’s something that happend to someone before? Thanks -cosmic z
Old 07-21-2019, 11:15 PM
813_350Z
813_350Z's Avatar
Yes. You have a short somewhere.
Old 07-22-2019, 07:59 AM
onecoolee
onecoolee's Avatar
is there any stereo equipment under the passenger side seat? Sounds like if the act of moving the seat caused the fuse to blow, there may be a wire pinched there or around the seat track. Be careful, there are airbag connections under the seat and if you turn the key on, with the seat unplugged, you will have to reset the SRS system.
galvestin314
07-11-2019 12:54 PM
Dillon Hall
02-08-2018 12:23 PM
Dr.Paulyy
06-08-2014 05:11 PM
Z33hr6spd
12-09-2009 06:13 PM
Quick Reply: Dash lights and radio not working!! HELP!!!!!
