2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
370Z Clutch vs. 350Z Clutch
Old 01-26-2009, 09:15 PM
cheeyo
cheeyo's Avatar
Default 370Z Clutch vs. 350Z Clutch
For you manual transmission owners, how does the new 370Z clutch compare to the old 350Z's? I've read a couple owners/reviews mention that the clutch is on the softer side, which sounds like the opposite of the old 350Z's stiff, long throw clutch. I would love it if you lucky 370Z 6MT owners could share you experiences regarding the following:
clutch travel - shorter travel than the 350Z? Or the same?
clutch engagement - does clutch still engage high off the floor or more towards the middle? Also, is the engagement point still really narrow, like an on/off switch - or is it more forgiving?
clutch weight - more/less/same effort required to push down clutch pedal?
Thanks guys!
Old 01-27-2009, 05:03 AM
99lspwr
99lspwr's Avatar
I would really like to know if the clutch sticks to the floor for a second in between high rpm shifts like the 07-08 clutches do...In other words, does it have one of those b.s. inline clutch dampners..??
Old 01-27-2009, 05:19 AM
tranceformer95
tranceformer95's Avatar
I didn't get to test drive a 370z yet but I've sat inside a showroom 370z, and driven a G37S coupe several times. (i'm pretty sure all drivetrain parts are identical from the G37 to 370z)
--> feels the same as my '05 350Z
--> high off the floor, between middle and top of clutch travel; no need to push the pedal to the floor during normal driving
--> feels the same as my '05 350z, which is A LOT softer than the 03 and 04 clutches that I've driven. I will say that the G37/370z clutch felt like it had more of a spring action to it, maybe the clutch on my Z is getting tired (it's already slipping a bit).
I will say this, switching between my Z and my brother's G37 is seamless as far as the clutch is. It's just that everything feels smoother and newer in his car.
Old 01-27-2009, 06:42 AM
bryan@Z1
Vendor - Former Vendor
bryan@Z1's Avatar
From what little I have driven our 370Z the release point is very high off the floor. It does have a fairly soft pedal and for the most part is pretty fool proof if you're used to a high pedal point.
Old 01-27-2009, 08:54 AM
35Z
35Z's Avatar
Thanks guys!
Clutch travel is shorter
Clutch engagement is shorter & narrower
Less effort than on my 05 350Z.
Old 01-28-2009, 04:58 AM
99lspwr
99lspwr's Avatar
???? anyone know this yet????
Old 01-28-2009, 06:49 AM
Datona Jess
Datona Jess's Avatar
My 08 never had what you are talking about so no.
If the 370 is at all like the G37S clutch, then it is a big improvement over my 06 and 08 Z's...
Old 01-28-2009, 08:12 AM
lemansz20
lemansz20's Avatar
I drove a g37s, and i felt that I needed to become a girl to drive that thing. It was soooo soft, compared to my old 04 350z, it made me miss that clutch, bc it was awesome to me.
Old 01-28-2009, 09:44 AM
El PreZidente
El PreZidente's Avatar
My clutch never sticks to the floor when shifting at high RPM either (08 Enthusiast).
Old 01-28-2009, 10:21 AM
99lspwr
99lspwr's Avatar
hmmm, funny...Are you guys shifting fast enough..?? I test drove an 08 enthusiast,an 08 base, and a 08 touring vert. that all had the same "clutch sticks to the floor for 1 sec" between 7500 rpm gear changes...
Old 01-28-2009, 10:23 AM
99lspwr
99lspwr's Avatar
I am right there with ya..My 04.5 enthusiast clutch felt much better then the newer 07-08 clutches...
Old 01-28-2009, 10:46 AM
El PreZidente
I shift as fast as the car allows without abusing it, from what I can tell. The shifter is pretty balky... I could stomp the clutch and yank back on the shifter as hard as I can with the gas still mashed to the floor I suppose, is that how you do it?
Old 01-28-2009, 11:53 AM
Hella
Hella's Avatar
apprarently you are the only one shifting fast enough to make the clutch not work properly.
Old 01-28-2009, 12:56 PM
99lspwr
99lspwr's Avatar
no,no..If you do a search, you will find exactly what I am talking about..The 07-08's all have an inline clutch dampner that slows fluid through the line resulting in a "cushy" high rpm gear change thus keeping the pedal to the floor for a quick second..
If you do a search for "clutch dampner" you will find other threads as well as pics....I guess if you 07-08 guys have never driven a 6mt from the 03-06 Z's it may just feel normal to you..
Old 01-28-2009, 01:02 PM
99lspwr
99lspwr's Avatar
I am not flat shifting or abusing the car/clutch in any way, just simply shifting fast....Matter of fact you can almost feel the gear transition delay for a quick sec. when this happens...
Old 01-28-2009, 03:25 PM
El PreZidente
AP2 S2000 is worse, I'm sure of it. Maybe that's why I don't notice it.
I've shifted at a little above 7K a few times, and not noticed the clutch slipping or anything. I'm never really on the gas until the clutch most of the way up, and the clutch comes up as fast as I let it.
Old 01-29-2009, 05:05 AM
Datona Jess
I disagree, I had an 06, and I felt the 08 had a slightly different clutch, but nothing that I can put my finger on.
I am not the worlds best shifter, but I dragged, autocrossed, and roadraced that car without any problems whatsoever, and I flat foot shifting that car a BUNCH of times.
The new clutch will be softer, but that is progress. That is what they want, smoother and still as strong and less noisy.
Old 01-29-2009, 05:38 AM
ACEMAN
Master
ACEMAN's Avatar
It is still setup the same way.
When i test drove the 370 I noticed the same exact thing happening like when i drove a nismo 350z.
Never had this issue on my 03
Todd
Old 01-29-2009, 12:27 PM
99lspwr
99lspwr's Avatar
Todd
WOO HOO!!!! My man...Maybe these guys will think I am a little less crazy now..lol
Old 01-29-2009, 07:26 PM
danlee1
danlee1's Avatar
Just got back from test driving the 370z. I currently have a 2003 and the 370z clutch is super super soft. No effort needed at all to engage the sucker...in fact, its even soft compared to a 2008 BMW 335i, which is pretty soft compared to my Z. I haven't driven any year Z other than mine, so I cannot comment how the differences between the new 370z vs the late model 350z's. As everyone else mentioned, the engagement point is pretty high on the 370z. It does shift nice though!
Quick Reply: 370Z Clutch vs. 350Z Clutch
