Picked my PPW roadster today^^Questions
Old Dec 5, 2003 | 07:27 PM
Nelson's Avatar
Nelson
Default Picked my PPW roadster today^^Questions
Hi,
picked my PPW roadster today and YEAH !! Z is Great car!!
But, i have a problem with opening the top, the dealer showed me today by unlock the center silver handle first and press the button, i did the same thing after i get home but it didnt work, anyone can help.
The stupid dealer shop gave me the wrong manual which is for the coupe so im not able to check the manual, gonna ask them for a correct manual tomorrow but it will be perfect if i can get a solution today.
I suck at speaking English, so it maybe some misunderstanding when you go thru my post. Make it simple: HOW TO OPEN THE TOP?
Yeah, im gonna post some pix asap^^
Old Dec 5, 2003 | 07:30 PM
Moroccan_Mole's Avatar
Moroccan_Mole
is the parking brake on?
Old Dec 5, 2003 | 07:32 PM
Nelson's Avatar
Nelson
so i need to step on the brake?
Old Dec 5, 2003 | 07:44 PM
Nelson's Avatar
Nelson
Get it,
Thx
Old Dec 6, 2003 | 08:23 AM
elentz's Avatar
elentz
Not a Z owner myself (yet) but in dealing with other roadsters, generally you have to pull up on the parking brake (handle just to your right) to open up the top. Hopefully that will clear it up for you a little bit
Old Dec 6, 2003 | 09:03 AM
AndyB's Avatar
AndyB
Default to drop top
To drop the top.
1) Do not lower top when it is wet or below freezing.
2) Stop car, keep foot on brake.
3) Push button to realease lock handle
4) Pull lock handle down until it releases the locks
5) Hold the button until all the hub bub stops.
It will not drop if the brake is not pressed. If you release the brake while the top is moving the top stops. You must then release the top button, re-press the brake pedal, then hit the button again. It is VERY strict about the brake pedal being pressed for the entire operation.
AndyB
Old Dec 6, 2003 | 09:20 AM
srmd22's Avatar
srmd22
BTW, the e-brake doesn't have to be engaged to move the top up or down on the ZR.
Old Dec 6, 2003 | 09:25 AM
Paul_BB_Guy's Avatar
Paul_BB_Guy
Nelson,
The manual I have is for the coupe and the convertible. Check again, there may be information on the top after all
Just to clarify Andy's instructions a bit:
1) Don't lower top when it's wet or temperature is below 32F/0C (it can damage the canvas and the mechanism)
2) Stop the car, keep foot on brake (you don't need to have the handbrake engaged)
3) Push the black part of the handle to release the silver part of the handle.
4) Pull the silver part of the handle down so the roof disengages from the windshield section.
5) Hold the roof button to the left and below the steering wheel until the hub bub stops.
When you put the roof back up, pull the silver handle to connect the roof to the windshield section and then push it up to complete the connection.
Cheers,
P.
Old Dec 6, 2003 | 10:06 PM
Nelson's Avatar
Nelson
thx for all the tips^^
I will memorize them.
Again, I will post some pix of my garage as soon as my buddies return the camera to me.
Old Dec 9, 2003 | 03:59 PM
srmd22's Avatar
srmd22
PPW looks like bird doo. JK, it's a beautiful color, 'grats!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
AchilleZ
Oct 11, 2015 09:45 AM
