Replace Elastic Bands (no drilling)
4 Attachment(s)
I purchased some Knit Elastic band material at the local fabric store.
It had to be cut it to the right size. You will also need 3M heavy duty double sided tape. There is enough to do this fix several times. Attachment 451739 First position the top so that you can cut the old bands out. Attachment 451740 Next wrap the 2nd bow with tape and apply the elastic band so that it will wrap all the way around the bow. Attachment 451741 Next add tape to the 3rd bow and wrap the elastic band around it. Make sure it is tight enough to pull the 2nd bow into position when top folds. Attachment 451742 |
Neat idea, mine are loose may give this a try.
Originally Posted by red roadster
(Post 9968337)
Clever!
I may supplement my replacement bands with something like this, as my top doesnt like coming down fully when its cold. I replaced my worn factory top, and the elastic strips with a HAARTZ Stayfast Canvas, by EZ-ON Autotops, but my top still hangs up at the ~85% open.
I'd like to buy some. Is there a website you bought this at?
Thanks, Ryan |
bump
Originally Posted by Slyguy_38
(Post 10004361)
Thanks, Ryan |
I bought the elastic at the local fabric store. They sold it by the yard or in pre-packaged lengths. I'm sure you could find it at a hobby store as well.
When the top on my '06 has trouble opening, I think it might be just that it's less than 50 degrees out. Opens fine after it's been in the sun for a few minutes and heats up. The elastics do appear worn out to me tho, and this is a great way to restore them. Thanks for putting this out there for us to use!
Ryan |
(Post 10011353)
Ryan |
Originally Posted by SHILOW
(Post 10017544)
You should try pushing back on the 2nd bow as the top folds to assist the elastic bands. I did this for about three years before I decided to replace the bands for the second time.
I pointed out to the dealer I bought my roadster from that the top doesn't like to open fully when it's cold out. I already knew why (elastic bands), but wanted them to look into it and fix it while the car is still under warranty.
They looked at it today. "It's the elastic bands sir. Common problem. We're buying the kit from Nissan and installing it for you. Parts should be in tomorrow. Take this loaner for a few days." Yay! |
(Post 10018320)
I'll make sure everything is operating smoothly. Thanks for the info!!
How do you get the 3rd bow tight?
They left the rivet pieces in after the repair. Took it back and they vacuumed them out. Fixed now tho.
Wow. That was fun |
first post
I am looking to buy a z350 here in Japan. One of the cars I went to look at is the color that I wanted but the roof did not fold down so I walked away from it since I read the 5th bow engine stories here. After reading It seems that the engine brushes wear out really fast and it is not that hard to replace. then I came along the elastic band issue. Finding this thread has helped me to get the confidence to probably buy a z 350. I have one question how do you get at the metal bars ? aren't they covered with some cloth on the inside ? sorry for the long post. best regards |
SHILOW....Thanks for sharing!
Originally Posted by anatak
(Post 10056406)
first post
