Window Alignment
Just replaced the driver's side window lift motor. Works fine except - the window is leaning inward about 1/4". This keeps it from closing. I'm baffled, as everything locates off the door panel. What am I missing?
Thanks, Kevin |
Sounds like you have misaligned regulator or 2. (The silver runners). For me, I use 3" masking tape to keep window all the way up, then install regulators, then do motor relearn. There are diy on here and YouTube. Good luck.
