Negative effects of top stowed for long periods?
First time 350Z Roadster buyer, long time roadster owner.
Normally my top goes down first of May and stays that way until mid November. Looks to be original fabric top. Can I expect damage, should I pre-treat?
"...my top goes down first of May and stays that way until mid November. Looks to be original fabric top. Can I expect damage, should I pre-treat?
Choosing to do that makes little sense to me, and I don't / won't stow mine for extended periods.
Nice ride, get a stubby antennae mod.
Thanks, I was looking for personal experiences of those that had left their tops down and their results good or bad.
The 350Z's top mechanism is quite complicated and I am frankly more worried about it going south with frequent use than the replaceable top, but I bet the top costs a pretty penny to replace. This 2007 top is in excellent condition and may be original to the car.
Why a stubby antenna? Better reception/looks? Factory replacement?
Thanks
Edit add: A stubby might help in the covering dept.
It's a stretch but my Miata cover almost fits.
Thanks
Certainly read about failures, specifically here on an enthusiast's forum, but I wouldn't stress over average & reasonable use. No clue what the mean-time-between-failure rates are and there are always failure exceptions but I have zero concerns with normal use. I do inspect and lightly lube all contact points on a consistent basis, including the latch and catches across the windscreen frame. You'll do what you consider is best but I wouldn't (and don't) leave the top stowed.
Purely aesthetics, specifically on the roadster. Top-down and OEM antennae length just looks "off" (opinon).
My roadster is not a daily. I use a fitted California Cover (which was not worth the price although the fit is excellent - too many friggin' seams, looks like ****) and I've kept the long antennae sock. That Miata cover looks like it fits well-enough to not waste coin on another.
stubby antenna?
