370Z Maintenance & Repair 370Z upkeep and diagnosing/fixing problems
Turn signal not cancelling Anyone?
Old 01-01-2017, 04:58 AM
35reilly
35reilly's Avatar
Default Turn signal not cancelling Anyone?
Have a 06 g35 few years ago I took airbag out to remove parts I was going to paint. Put back together and ever since when I put turn signal on and make the turn it will not cancel out. Anyone have any suggestions? Also have a airbag light on. Idk if this is something from that as well. Any help would be great. Did a search and not much on our cars about this. Thanks!!
Old 01-01-2017, 07:05 AM
Freise
Freise's Avatar
There should be a "turn signal canceler" piece inside the steering wheel. It's usually plastic, and has a couple of tabs on it that are supposed to turn the signals off. It needs to be aligned properly when you remove/replace the steering wheel, so my bet is it's not aligned properly.
Old 01-01-2017, 10:17 AM
35reilly
35reilly's Avatar
Cool bud. Thxs I'll check it out and see
Old 01-02-2017, 08:19 AM
35reilly
35reilly's Avatar
Easy fix. Wasn't aligned correctly took everything off aligned it correctly and wham works. Thanks buddy appreciate it!!!!
