2-way/3-way speaker question?
Can someone explain the difference between a 2-way and a 3-way speaker and why I would want one over the other? I'm not looking to install separates, just replace the factory speakers with upgrades.
Thanks |
2 way has tweeter and mid driver
3 way has tweet mid-bass and mid-range driver also coaxial has tweeter mounted on mid driver factory is 2 way system |
Which one is more efficeint and normally sounds better?
three way sounds better, but will require a custom install of some sort.
if you want to keep "stock look" I would go with a 2 way component system and mount the speakers in the stock locations. The 350 is a 2 way system. |
Would I be correct in assuming that if I have a sub in the hatch then I wouldn't want 3-way in the doors?
somewhat correct..... but normally a sub is just low end bass usually cut off about maybe 70 or 80hz.... if you have a three way (tweet- for highs, midrange- for vocals, mid-bass for kick drums et cetera , and sub for bass. I don't use the sub for just that boom boom sound you hear down the street. When tuned in well for the rest of the speakers a sub will add warmth and depth to the music. Imagine the vocals with that low hum coming from that diaphram... that what you will add with a sub. The major benifit to a 3 way system is that each speaker is playing only a narrow range of music specifically made for each driver.
Shalin soccer rules! just hope miramax doesn't screw it up |
My sub cuts off at 120, so I guess I would still need the 3-way speakers to handle the frequencies between 120 and the midrange. I could put a little crossover on them so that they dont handle the really low stuff.
if you want a 2 way system can be crossed that low ..... but a 3 way would be better.... but the install will have to be very custom.... it will sound great though.
I'm referring to coaxial speakers, not seperates.
I posted this question to a car audio message board, and 90% of the responses favored a 2-way coaxial over a 3-way. Now I'm confused.....are you telling me that a 3-way speaker would require modification? I don't see how if the speaker depth of the two is the same? |
let me clarify....
coaxial speaker has tweeter mounted on bass driver... (2 speakers total) 2 way has seperate tweeter and driver (4 speakers total) 3 way has 1 tweeter and 1 midrange and 1 mid bass (6 speakers total) the only reason why anyone would tell you coax is better is possibly the ease of install. if you just look at price 2 way is more expensive than coax and 3 way is more than 2 way. go to sounddomain.com... they are usually very knowlegdable |
Originally posted by imntcrzy let me clarify.... coaxial speaker has tweeter mounted on bass driver... (2 speakers total) 2 way has seperate tweeter and driver (4 speakers total) 3 way has 1 tweeter and 1 midrange and 1 mid bass (6 speakers total) the only reason why anyone would tell you coax is better is possibly the ease of install. if you just look at price 2 way is more expensive than coax and 3 way is more than 2 way. go to sounddomain.com... they are usually very knowlegdable So, having gotten that out of the way, which will be better replacements for the factory speakers....2-way or 3-way coaxials? Thanks! |
in depth answer....
coax pros 1 easier install 2 tweeter is on same plane as driver.... improves soundstage and imaging 3 price cons 1 crossover tends to be less quality 2 individual components within coax tend to be less quality 3 smaller drivers 2 way pros 1 better tweeter 2 better crossover 3 larger drivers more sound control 4 better quality drivers cons 1 price 2 install costs more plus you have to mount crossover 3 tweeter placement can be crucial, but you can mount in factory stock location. also a 2 way system is very easy to make look "stock" hope this helps |
I'm still not getting the answer I'm looking for.
What is the difference between a 2-way *coaxial* and a 3-way *coaxial*, and why should I choose one over the other? I'm not concerned with seperates...I know their quality and why they're better than a coaxial. |
ok sorry .... in theory 3 way coax would be better, the problem is the midrange on the 3 way coax is very small and may cause vocals to not have a full sound.... I guess that's why they prefer 2 way coax
http://www.focal-america.com/catalog/Access/165ca.htm check this one out |
If this helps i have three way 6.5 coaxials in front and rear of my current car and also have aftermarket tweeters high on the doors near the dash and it sounds amazing. Personally if you have the money i'd say go with that setup. Thats just my opinion though
