MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Audio & Video (https://my350z.com/forum/audio-and-video-52/)
-   -   I'm Modding My Ps2, More to come! (https://my350z.com/forum/audio-and-video/102629-im-modding-my-ps2-more-to-come.html)
alininger2001 Dec 14, 2004 01:56 PM
Hey guys, I have decided to mod my PS2. I am basically adding a 120 gig hard drive and will have the ability to load ps2 games and dvd's directly to it. I will post a how to if it works, and it will work.
alininger2001 Dec 15, 2004 06:15 PM
Sorry for the teaser, just to let you know this is a very simple installation. Everything will fit inside the ps2 and NO soldering will be needed. The approximate cost will be about $130 to do($160 if you do not have a network adapter) The load times should decrease dramatically, and you will never have to switch discs again. My guess is that you could probably store 50+ games or movies directly to your PS2.
hndumafia Dec 15, 2004 06:45 PM
hdloader? ive got the software, but haven't gotten around to buying a network adapter or hd yet.
ive also got a mod chip, but never installed it because i dont have a soldering iron in school
jcr847 Dec 15, 2004 07:11 PM
old news, I set mine up alost a year ago
alininger2001 Dec 16, 2004 03:44 AM
Sorry if it is old news, I never needed to do any of this until I installed a PS2 in my car.
alininger2001 Dec 16, 2004 03:47 AM
You shouldn't need the mod chip if you are copying original PS2 games or DVD's. You only need it to play CDR's ond DVDR's.
hndumafia Dec 16, 2004 11:30 AM
yea i know - i got the chip before hdloader was released, and ive got some games on dvdr's. so i figure since i have the chip already i might as well install it.
alininger2001 Dec 19, 2004 05:33 AM
You can format the hard drive with HD loader, put the hdd in your pc as a slave, and use HDL Dumb to copy the dvdr's over to the ps2 hdd and hdloader will be able to play the backups.
jcr847 Dec 19, 2004 05:57 AM
that's the way I do it, I dont have a chip.
hndumafia Dec 19, 2004 11:08 AM
will that work with the regular hdloader, or only hdloader advance?
alininger2001 Dec 19, 2004 07:29 PM
both, the software will play the backup game without being modded. The problem is the ps2 won't read the disk to copy it to the HDD. That's why you copy the files from a PC and play them in the PS2.
Update, I got a super deal on a 250 gig HDD. The software will only recognize the first 200 gigs, but that's more than enough. I am compiling my games as we speak. I am working out a way to copy DVD 9 games, I'm pretty sure Gran Turismo 4 could be a DVD 9 game.
hndumafia Dec 19, 2004 09:24 PM
awesome... i wont have to bother putting in that mod chip then.
Jun Dec 21, 2004 07:49 AM
no need to put a mod chip to play backup games. just get the flip top case.
hndumafia Dec 21, 2004 08:53 AM
you mean the new thin one? but then you can't use the hdloader because it requires the use of a network adapter and for a harddrive to go into the playstation.
alininger2001 Dec 23, 2004 12:26 PM
Finally got it done, the HD Advance 2.0 program recognized my 250 gigs as 233 gigs. So far I have made time to install about 10 games to the PS2's new hard drive. Hopefully by the end of the month I will have enough time to load up all of my games(50+). This works great in my Z. I don't have to switch discs/smush passengers anymore, all I have to do is crack open the door(with the seat still reclined back and turn on the PS2/reset it to switch games.
AParshall04 Dec 24, 2004 10:40 PM
my best friend does this type of modding as well, but for xboxs instead of PS2s. He does it without a mod chip, no soldering, installs harddrives that can do all sorts of crazy things. He usually sticks a 250gb harddrive, stores over 100 games + all the old arcade classics. Pretty cool stuff, PM me if youre ever interested in having him mod one for you, hes got a business going.
BlueDragonZ Dec 25, 2004 09:50 AM
This is all new to me so bare with me, please.
I have the old PS2 but have the new THIN one on order. This is the one that I will be installing in my Z. Has anyone done an actual WRITE UP on how to MOD a PS2 for those of us that's a NEWB to it? I do have 50+ games that I would love to upload. Thanks is advance.
alininger2001 Dec 27, 2004 10:58 AM
Here's a quick write up.
1. First go to best buy and get a network adapter and an internal hard drive. (the hard drive can be 40-250 gigs, make sure it is an ide hard, drive not sata. Buy a Maxtor, they fit perfectly and they work. 9Beware of seagate and western digital)
2. Order this software disc......
http://www.modchipstore.com/PS2_HDAd...c-p-16188.html
3. Set the hard drive jumper to master. If you don't know how to do this, look in the owners manual.
4. Connect the network adapter to the IDE and power connections on the hard drive. The maxtor hard drive will match up perfectly.
5. Slide the hard drive/network adapter into the expansion bay on the back of the ps2. Tighten the two screws on the network adapter to hold it in place.
6. Insert the HD Advance disc and turn on the PS2, the software will ask you if you want to format the drive, click yes and your done.
Note: Only convert ORIGINAL games that YOU own to the hard drive. Anything else you copy over to it is considered piracy and therefore is ILLEGAL.
rbaggett1 Dec 27, 2004 12:14 PM
I have HDLoader and everything works like alininger2001 mentioned above except for the following:
1) The only size hard drives that it supports are 40-140GB. I heard that HDLoader and HDAdvance are very similar but I don't know if HDAdvance has a limit or not (may alininger2001 can verify this for us).
2) I only buy Maxtor hard drives because I had a very bad experience with Western Digital. Make sure you check the software's website for a list of compatible hard drives.
alininger2001 Dec 28, 2004 02:49 PM
I have hd advance 2.0, it says it only recognizes up to 200 gigs, but it recognized my 250 gig HDD(It doesn't seem to have a limit). Any maxtor drive that is IDE should work, I beleive they are all compatible. The list on their website is composed of user posts and is not very comprehensive.
Western digital hard drives won't fit into the connectors on the network adapter, don't even try using one of those.
