MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Audio & Video (https://my350z.com/forum/audio-and-video-52/)
-   -   2 12" W6V2's versus 2 10" W6V2 (https://my350z.com/forum/audio-and-video/128512-2-12-w6v2s-versus-2-10-w6v2.html)
GQ 350z Jun 20, 2005 01:25 PM
Hi all:
Considering that price is not an object, which would you choose? I'm a sq oriented person that likes clean/tight bass. Where I work we have a RSX show car done by Good Guys with a pair of 12w6v2's that sounds insanely good.
I'm willing to get the fiberglass work done in order to get the pair of twelves under the strut bar. Looking for opinions of what would be better for me...I listen to mostly hip hop and some punjabi music ahhahahaha basically stuff that has a lot of good bass lines.
ravi
momo 350z Jun 20, 2005 02:00 PM
i used to work at good guys in east palo alto, iv'e sat inside that rsx and it sounds insane..with your type of music i would go with the 2 12's..but you could go with the 10's in a ported enclosure and sound just as good if not better than the 12's and save you some $$ in the process
GQ 350z Jun 20, 2005 02:26 PM
Yah..I work at Good Guys and our store (stockton) owns the car now. I used to have a ported 10w7 in the car, and it sounded like crap. This time I'm going all out, at least 100 sq. ft of dynamat/fatmat and making sure I get exactly the sound I want.
I'm glad you have heard the car I'm talking about...thats exactly what I want to do. Do you think 3-ways would be feasible (the same way the rsx had it) ? I'm 90% sure I'm going to do the pair of 12's and just let the fiberglass box under the strut take care of the fitment problems.
Any other opinions bro?
ravi
stu46 Jun 20, 2005 09:13 PM
I know a guy that's running 2 12w6v2 powered by an Xtant 600.1 to each, ported in his civic. Crazy loud. Enough to start to see webbing in his paint and break his power sunroof. I'm running 3 10w6v2 sealed with an Xtant 300.1 to each. Can't really compare because it's 2 different applications but both sound good.
GQ 350z Jun 20, 2005 09:59 PM
Ok well I'm positive I'm going with sealed 12's or 10's. I'm trying to decide what to do still. As long as I can make it fit thats what I will do.
Stu, do you have hella dynamat? I'm going to use quite a bit. When I had the 10w7 it rattled up my hatch area. I think that took away from the overall sound. Can the bass be heard outside the car too?
ravi
stu46 Jun 20, 2005 10:05 PM
You can get about 2cuft if you remove the spare. Enough for 2 12 or 2 10 sealed.
There's a few strips of dynamat like material, not much. Mainly to reduce the road noise from coming in. My hatch doesn't rattle anymore cause I removed the brake light shade and disconnected it.
I don't listen to the stereo very loud when cruising so I don't know. If this helps, I listen to it at about 10-12 when cruising and 16-18 on the freeway. 22 is about max. When the volume is at 12, it can barely be heard from the outside if my car is parked. But if you play some crunk at 20, I'm sure it would be heard. HTH
GQ 350z Jun 20, 2005 10:12 PM
Cool. I dont know what it is about the Z but the rsx with the pair of twelves is very loud and clean on the inside and there is absolutely no rattle on the outside...just the bass or the air pumping out the windows. Even at conservative volume levels its sick sound wise.
Thats what I want with the Z. I'm going to do the under the strut box and fiberglass it out to fit the twelves.
thanks!
ravi
Bubble Jun 20, 2005 10:30 PM
hey Ravi,
since you work at Goodguys, any hook up on the JL stuff? hehee
GQ 350z Jun 20, 2005 10:35 PM
There is a bunch of markup on JL stuff...its price protected and they track what you buy so in short not really =(
sundawg Jun 20, 2005 11:19 PM
haha so were going wit the 12's or 10's ravi haha
i think im going wit 2 10w6v2's with that 1000.1 amp and the under the strut box. leme knoe when we can go ahead and get all that stuff done.....
Bubble Jun 20, 2005 11:23 PM
JL Audio 1000.1 cost a lot. Wholesale would run in the high $600.
sundawg Jun 20, 2005 11:28 PM
umm actually on ebay they can be found for about 600 and i got a few buddies who might be able to get me a better price... yea the jl 1000.1 is the only amp i would run to my w7's or w6's. if money wasnt a factor what would u reccomend. 2 10in w7's/w6's or 2 12in w7's/w6's im decideing this week sometime on which setup, either way i was going wit the under the strut bar off ebay... thanx
GQ 350z Jun 21, 2005 07:36 AM
I would say two 10w7's will be insane. TWo 12w7's will be overkill for sure. Two 10w6v2's will be loud and provide great sound. I'm only going with the 12's b/c I'm doing a custom box probably.
the box on ebay is a great buy. i might end up doing a pair of 500/1's for a more show look. i'm still deciding--but seriously anything you choose will be fine. For the recommended airspace of the box and to keep costs down I'd probably go with the 10w6v2, b/c the W7 needs more than a cube of air space in order to sound right (sealed).
peace!
ravi
sundawg Jun 21, 2005 11:57 AM
yea then im going with 2 10in w6v2's with the 1000.1 amp, leme knoe when u wanna start our little project or if i can start mines early since i have the funds availible all ready... but anywayz wut time does ur bros party start on saturday cause u knoe i gotta show up early, u wanna detail our cars the day b4 or something? leme knoe laters
GQ 350z Jun 21, 2005 12:05 PM
Cool..I'll check to see what I can work out for you...I'm going to detail the whip probably thursday/friday or something. Where ya gettin the amp from? I cant wait to hear the setup..
Should I put my kit on first and then do the system? What would you do ahhaha...I cant decide.
ravi
sundawg Jun 21, 2005 12:45 PM
haha personally since u already have the kit n **** i would go that route, but on the other hand the kit might look a lil wierd witout ur rims.... umm so i would wait for ur rims n put all of the exterior mods on at the same time....i thought that i would get everything through u, including the 10in w6's n the 1000.1 leme knoe whats up, i have all my funds ready.... yea hit me up whenever u detail ur car, i will bring mines over to n we can do both together then maybe ur mom can make us some foood ahaha... ps i dont knoe if ur moms told u but ur coming over to my house for dinner on friday.. well let me knoe wuts up wit the system ...
peace
GQ 350z Jun 21, 2005 12:47 PM
Ok i'll see what I can do. Hahah she didnt tell me that yet. I meant I was going to put the kit on after my rims come (about three weeks).
I'm having a hard time deciding what to do first. Probably kit then small system. But, if the car looks sick with just the wheels I'm going to put something insane in the trunk.
i'll talk to my manager tomororow.
ravi
xtrememan315 Jun 21, 2005 03:41 PM
Hey GQ,
I have two JL 12w6v2's and I was wanting to do a ported fiberglass box, I love the LOUD bass and was wondering do you think it would work?
UCLAzzz Jun 21, 2005 08:18 PM
I hope ya'll post picture with the final product...I'm fixin to put some bumps in the trunk......"bass in your face...not an eight track"....
GQ 350z Jun 21, 2005 08:54 PM
xtreme, I wouldnt do the ported pair of twelves. I mean its feasible, but the airspace for each of those ported is like 1.5 cu ft. So thats a good 3 cu. ft in an already small car.
There is a lot of cabin gain with the Z. Essentially what that means is that once the subs are in the car, the subtleties of the interior increase the decibel levels. I think you will be extremely impressed in a very sealed and tight box for the 12's. It will still need to be glassed if you want them to fire off the hatch area.
Anyway, I'll post what I decide to do. Are yours already installed? I'm curious what you think of them sound quality wise.
I'll most certainly post pics. The car is completely under construction. Its literally going to be a daily driven show car.
ravi
