Serious noise after new system installed..help
on
i put 2 crossovers and an aftermarket amp above the fuel tank, and the power cable along the passenger side to bettery, 2 rca cables on the driver side, I also grounded HU to chassis, I did check the grounding..everything
but the sound still picks up noise, then i used another hu and amp to test the sound,,it still picks up noise..what should i do? so disappointing
on
dc567,,,where is your speaker wire running and what gage wire (power wire,ground wire ect) per equipment? Also, did you check all of the ground connections? I would make sure your powerwire is not crossing over your speaker/rca cables in the cubby where amps are installed....I am in the process of my install, I ran the power wire, as you said, down the passengerside,,,,I am running my RCA's down the center console to the right and running my speaker wire to fronts up center console to the left <e-brake side>. I know there are lots of people here who have way more knowledge of this problem,,,just thought I would offer what help I can....
on
Did you grind the paint off the surface points where your grounds are?
on
Originally Posted by colds14
What type of crossovers are they? Alot of old ones and new ones will produce noise. Try bypassing them and see what happens.
on
guage 4 for power and ground cable
12 for speakers
i also ground the HU headend by 2 guage 12 wires
they tend to pick up noise when too close
on
Originally Posted by disturbed2483
i had the same noise, tried for ever to fix it and i couldn;t so i just took it to an audio shop and they fixed every thing for me.
I got fixed by connecting a 4 guage wire to HU,
on
Wow, that is a huge power wire for your headunit.......I am running a 4g wire from my battery to distribution block, for the power source for my two amps.
on
Did you use the metra harness for your headunit power supply? I know from my past years experience, the harness's in most cars will provide good, solid, power, constant power and sometimes ground..to the headunit
