MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Audio & Video (https://my350z.com/forum/audio-and-video-52/)
-   -   Plz help can't find a speaker that will fit! (https://my350z.com/forum/audio-and-video/239826-plz-help-cant-find-a-speaker-that-will-fit.html)
DanimalB Dec 30, 2006 12:29 AM
I am trying to replace the stock bose subwoofer behind the driver seat in my 06 Z. When I took the bose sub out it seemed to be much stubbier than I imagined, and the sub that I purchesed to replace it (the JL 10w7) was too large and hit the body of the car on the bottom part inside the stock sub box. I really do not want to put a sub in the "trunk", so Im asking anyone who knows of a decent subwoofer that will fit in the stock box with no problems? Please Help!
ZSpectrum Dec 30, 2006 12:57 AM
put a spacer behind the jl maybe, or dent the area where the jl sub will go
CaliTouring Dec 30, 2006 01:15 AM
this is actually a good question. i have an 06 touring and if there is a sub that will fit in the stock box then i just might consider it as long as it will work just fine wit the stock bose head unit.
MustGoFastR Dec 30, 2006 03:53 AM
Holy crap, dude, you ned to do some research and know what you're doing (not to mention post in the correct section) before dropping coin on something like a W7 series sub.
You NEED a box for that sub; there's no way around it (this, asside from the fact that that sub is MAJOR overkill if just putting it with the stock bose system. I hope to God you're not trying to just plug it in, either; you need a serious amp to drive that thing). Only way you can do a "drop-in" replacement for the bose sub is to get a true free-air sub and it still won't sound as good as a sub in a proper enclosure. Some people have tried converting that compartment INTO a sealed enclosure, but the labor to do so is cost prohibitive compared to an under-strut box. Do it right or don't do it at all. Hit the A/V section and start reading up/looking at what others have done.
z350boy Dec 30, 2006 06:32 AM
If you want to install another sub in the stock sub location you can check the folloing site:
http://www.wickedcas.com/gallery/mai...boxes/350zmbx/
You will see a custom fiberglass enclosure designed to fit in the stock sub location. They can also advise you on a good sub to use. Just my 22c :)
Paul350Z Dec 30, 2006 06:47 AM
Bose blows.
The Bose amplifier isn't going to put out enough power to drive your JL subwoofer.
http://i6.photobucket.com/albums/y21...ereoWork24.jpg
Also that subwoofer is designed to work inside a sealed or vented box. The trapped volume of air becomes a part of the system and acts as a spring that controls the woofer.
DanimalB Jan 1, 2007 10:42 PM
Thx for all the advice I have a better idea of what Im getting myself into. Ill keep the w7 that I have, and get into one of those boxes that I see http://www.wickedcas.com/gallery/mai...boxes/350zmbx/
And no as an answer: "that sub is MAJOR overkill if just putting it with the stock bose system. I hope to God you're not trying to just plug it in" Im putting in infinity kappa perfects all around to compliment the JL. Thanks again.
savvy Jan 2, 2007 05:41 AM
hahaha I didn't realize the stock Blose amps were they crappy....they really don't give you much for the extra like 1K that they charge for Blose stuff
blasian Jan 2, 2007 05:45 AM
You may want to find out the dimensions and depth of the box before you purchase it.
MustGoFastR Jan 2, 2007 08:23 AM
Bad link. Which box are you looking at?
Good to know you're upgrading the rest of the speakers as well, but it was the amps I was most concerned about; you'll need new ones.
seekndestroy19 Jan 2, 2007 08:57 AM
i have a premier2504 10" sub in the stock subwoofer location and it works great. of course i had to make a spacer out of mdf then made a fiberglass piece in place of the original panel with another spacer on that. the magnet on the sub is huge so it takes away alot of air space and i had to put this cotton material inside the space to make it sound better.
