Do 06 or 07 Z's play MP3's?
I have an 05 roadster and it doesn't play cd's with MP3's do the 06 or 07 stock head units play cd's with MP3's?
Also I assume it's a simple swap from an 05 stock head unit to an 06 or 07 am I correct or is there a size & wire config difference? thanks |
Yes. Only bose headunit plays mp3
06 Touring with Bose plays MP3s. However, I do not believe it will be a simple swap to change decks.
Correct, you can't swap a non-Bose HU with a Bose HU.
Also, you will have fittment issues with the 06-07 headunit going into an 05. The dash design changed on the 06 and up.
I have the original bose 05, but if it the 06 doesn't fit then I'm **** out of luck I guess. I much prefer the stock look.
Thanks guys! |
| All times are GMT -8. The time now is 02:42 AM. |
