Noob question
on
Noob question
I bought a used 350z and the owner before me installed a single din alpine unit. I'm looking to put a double din this weekend. I wanted to know what do I need to buy, considering an aftermarket stereo has already been installed? And also do I need the original bose bracket?
snobird
on
either the metra kit or you can cut your current kit, but i would def buy a kit since so cheap.
the brackets i believe are still there, when you take the head unit out there should be a metal bracket on each side. will have 4 screw holes on each side which attach to the radio (only 2 screws would be used on single din, 4 on double din and two on each side that screws into the dash trim piece
on
I had the same problem. Ordered this kit from eBay
Just go there and look for 2 din kits. It doesnt have any brand in discription, but at least brackets are there.
