MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Audio & Video (https://my350z.com/forum/audio-and-video-52/)
-   -   Where's a good ground point? (https://my350z.com/forum/audio-and-video/469253-wheres-a-good-ground-point.html)
xthejokerx Dec 27, 2009 03:35 PM
Im installing a gauge on my a pillar and I need to find a grounding point near the foot pedals. There are several bolts on top of the pedals but I do not want to remove them as they may cause danger if I do not tighten it at the OEM spec... Is there any other point above the pedals that's good for ground? I do not wish to wire it all the way to the radio bolt.
Thanks
GT-Z Dec 28, 2009 06:25 AM
anything metal to metal is a good ground
KPierson Dec 28, 2009 04:18 PM
I've used the ground wire going to the VDC switch for quite a few modules and that works pretty well. If you are in the drivers kick it would be very easy to use a self drilling pan head screw and a crimp on ring terminal for a very solid, very reliable ground.
