2003 OEM RADIO Brackets
Old 02-03-2019, 01:41 AM
ca6vtec
ca6vtec's Avatar
Default 2003 OEM RADIO Brackets
So my z came with a single dim aftermarket unit and I was not aware that I needed the OEM brackets to install a double din unit. Is there a workaround for this issue? Is there a kit that comes with brackets that actually works/fits well?
Old 02-03-2019, 02:34 AM
Spike100
Spike100's Avatar
crutchfield.com
Old 02-03-2019, 04:47 AM
travlee
Master
travlee's Avatar
Received 9,045 Likes on 6,511 Posts
Courtesyparts.com of you want the factory ears
Old 02-03-2019, 05:12 PM
JTeeAre
JTeeAre's Avatar
I was just in the same situation as you around a month ago. I got mine from z1motorsports.com
Old 02-08-2019, 08:58 PM
Chihuahuamaster
Chihuahuamaster's Avatar
Just a forewarning, you will likely have to drill new holes in the brackets for your aftermarket double-din.
If this is necessary, I would take the entire dash peice out of the car, so you can line everything up easier.
