Screen the size of your Nav Door *PIC* - HUGE SCREEN
I am seeing quite a few 7" screen setups in the Z - but I was just a bit curious if any one has seen someone that possibly took off the Nav door completely and molded a screen to fill out the entire space? I haven't measured to see how big it would be. . . but I just think it would be so nice to have a huge screen to fill up the entire area.
What does everyone think about this? |
http://www.elegantwooddesign.com/ima...s-tokico-z.jpg
This was the size I am talking about. I just wanted to know if anyone knew what screen this is, and if it's possible to have it molded to be flush with the dash? |
I can't see how you could get it perfectly flush with the dash since it is slightly curved and screens are, by design, flat. I would think you should deffinately be able to get it closer to flush than that install however.
It could be done flush, but you would defintely have to fiberglass something that fills the space left with the curve of the dash.
should do a little fiberglass work to get the screen to blend in better withthe curved dash
itd work. one of the great things about the Z's dash is that it conceals the screen so neatly. not that it wouldnt look awesome, but always gotta worry about theifs. the less they can see the better.
is that CF wraps or CF material dash?!?!
thnx! |
