Go Back  MY350Z.COM - Nissan 350Z and 370Z Forum Discussion > Marketplace > Private Classifieds > Audio Video
Reload this Page >
FS: Custom Sub Enclosure, A-Pillars, Kick Panels, Illusion Audio C10XL Sub
Audio Video Headunits, Monitors, Radar detectors, Subwoofers, etc...
Old 10-29-2018, 04:19 PM
aredd2009
Default Custom Sub Box w/ Illusion Audio C10XL(WILL SHIP), Kick Panels, A-Pillars
Sub Enclosure and C10XL Subwoofer - $650 (Local Pickup Available)
If you would like this item shipped it can be done, but be warned that due to this items size and weight, shipping is somewhat expensive (West Coast: Around $140, East Coast: Up to $250)
If interested, send me a PM with your location and I can estimate the exact shipping costs.
Custom Klick Panels - $120 Shipped
Custom A-Pillars - $120 Shipped
All components will fit any year 350z
The spare tire well enclosure / False floor was made by JT of JT audio and accessories in CA. It is approx. 0.75 cu. ft in internal volume (perfectly matched for the illusion sub). It requires no modification except removal of your spare tire and existing trunk mats. It mounts directly to spare tire threads with a single bolt. No assembly is required either as all pieces simply fit together like a puzzle. Carpeting is black and matches the black z interior very well. It has alcantera material around sub cutout and on amp finishing piece which was originally for a JL audio HD amplifier (not included), and breathable carpeted covers so it looks like you don't even have any audio equipment in your hatch if you so choose. The JL audio amp finishing piece however can be removed and other amps can be mounted in its place. Amplifier platform dimensions are 18.25 in x 8.5 in x 2.25 in. (See Pictures) Subwoofer does not screw in but instead uses threaded inserts and allen bolts. Speaker wire is 12 gauge Stinger. I originally paid $1000 just for this custom enclosure/false floor.
Illusion C10xl sub is in excellent cosmetic and working condition. Illusion audio XL subs use patented XBL^2 technology therefore they can handle lots of power and have tons of low end extension with virtually no distortion. It is a 10 inch dual 2 ohm sub therefore it can be configured either as 4 or 1 ohm nominal impedance. RMS Power handling is 500 watts, but this sub can easily handle up to 1400 watts and I recommend an amp capable of around 1000 watts RMS. Look around on car audio forums and you will find that anything Illusion Audio is top of the line stuff. Their XL line of subwoofers are considered some of the best subwoofers available in terms of output and sound quality hence why this sub is $850 new. There is no other 10 inch sub on the market currently that will play as loudly, blend as well, and be distortion free in only a .75 cu ft enclosure.
The kick panels were made by Bing of Simplicity in Sound CA. They pop directly into place of the original panels and require no mounting hardware, they are custom fiberglass and upholstered in black alcantara material. They are also extremely well deadened with cld and then packed with a non hardening clay material. They also come with removable speaker grills to prevent damage to speakers. Please keep in mind that these kick panels were made to fit shallow mounted speakers (Illusion audio c6 components with a mounting depth of 2.1"), although you could probably get by with a 2.5" mounting depth. Cutout diameter is 5 1/4 in, outer circular diameter is just over 6.5 inches. I would recommend running low profile speakers like the illusion audio c6 or their less expensive luccent L6 components. You can also go with their electra line of speakers as the tweeter fits the a-pillars as well,but the mid bass may be a tight fit as far as mounting depth. If you don't want to spend too much on speakers the Pioneer TS-A652C component set would work well with minimal modification. The audio frog gs60 mid bass speakers would also work well in these kicks These would require the dead pedal to be removed, but they will work for manual z's.
Custom A-Pillars were also made by Bing of Simplicity in Sound CA. They are custom fiberglass and upholstered in a vinyl material that matches the black interiors of the 350z. Also plug and play and require no mounting hardware as they pop into the pillar area like an oem piece, in fact they are simply modified oem panels. Again these were made for the illusion audio c6 component tweeter and would work with their less expensive luccent l6 or introductory electra e6 component tweeters or any other tweeter that will fit a 43mm cutout hole. As stated above the Pioneer TS-A652C component set should work well if you don't want to spend too much $$.
I don't have any pictures of the kicks/a-pillars installed but I have pictures of another vehicle that is nearly identical to mine
Installed in Vehicle with JL HD amp:
Illusion C10XL sub
Installed they look very similar to this, except the kicks are actually a little more recessed and angled a little more inward.
aredd2009 is offline
Old 11-05-2018, 07:15 PM
aredd2009
Bump
Old 11-05-2018, 08:36 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 1,516 Likes on 1,040 Posts
FS prefix added, pending move to Marketplace. glws.
jhc is offline
Old 01-05-2019, 05:07 PM
aredd2009
BUMP
Old 03-23-2019, 06:09 PM
aredd2009
Bump
Old 05-08-2019, 09:34 PM
aredd2009
Price dropped, $650 enclosure/sub, $120 for pillars/kicks (200 for both).
jdmfetish
04-22-2019 06:58 AM
ShineMaster
09-02-2018 12:56 PM
anotheraznguy
11-14-2017 06:26 AM
onecoolee
Audio Builds
54
04-27-2005 02:16 AM
Quick Reply: FS: Custom Sub Enclosure, A-Pillars, Kick Panels, Illusion Audio C10XL Sub
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
