Brembo Racing Anti-Knock Back Seals
Old 03-30-2007, 07:16 AM
Kolia
Kolia's Avatar
Default Brembo Racing Anti-Knock Back Seals
Just a quick note to say I値l be mounting these on my OEM Brembo痴 (44/38mm fronts) as soon as they get in. I知 curious to see how they値l do. I値l keep you posted.
Anybody ever tried them? I think it痴 pretty new stuff?
http://www.hrpworld.com/index.cfm?fo...action=product
Old 03-30-2007, 07:39 AM
dklau33
dklau33's Avatar
how does these seals function to prevent knock back? how do they compare to using springs?
Old 03-30-2007, 07:47 AM
Kolia
Kolia's Avatar
I don't know,
I would say the seal uses the fluid pressure in the caliper to generate friction and a one way resistance to limit the piston's movement back into the caliper.
I'll take some pictures of the seals when I get them.
Old 03-30-2007, 07:55 AM
Z33_SPL
Z33_SPL's Avatar
Nice find. Subscribing.
Old 03-31-2007, 06:34 AM
GaryM05
GaryM05's Avatar
Keep us posted...this will be interesting.
Old 04-01-2007, 07:55 PM
commasense
commasense's Avatar
Right after rebuilding my calipers with standard seals, I find out about this. Just great!
Let us know how they work, Kolia. And hang on for a lengthy post from me on my experience rebuilding and repainting my Brembos. I hope to have it up in a few days, complete with pictures.
Old 04-02-2007, 05:26 AM
Kolia
Kolia's Avatar
Okay, so you値l have your revenge by posting your brake rebuild topic two days after I致e rebuilt mine ?
Lol
Old 04-02-2007, 05:38 AM
Mike Wazowski
Mike Wazowski's Avatar
interesting
Old 04-02-2007, 06:29 AM
commasense
commasense's Avatar
Lol
Exactly!
Old 04-02-2007, 07:34 AM
John
John's Avatar
Repainting? You mean you have washed away your burnt badge of honor James?
Old 04-02-2007, 07:43 AM
commasense
commasense's Avatar
Why, yes, I have.
Last edited by commasense; 04-02-2007 at 07:47 AM. Reason: VB didn't warn that attachment was too big.
Old 04-02-2007, 07:59 AM
Kolia
Kolia's Avatar
Why, yes, I have.
Shame on you !!!!
The tracked-bronzed Brembo's should be worn with pride!!!
Old 04-02-2007, 08:03 AM
John
John's Avatar
Why, yes, I have.
Well, I have to admit that those do look pretty nice James... look forward to reading your thread...
Old 04-02-2007, 08:13 AM
THE TECH
THE TECH's Avatar
What difference are these seals supposed to make?
Old 04-04-2007, 05:33 AM
Nihilation
Nihilation's Avatar
I think it is to prevent the piston from traveling back into the caliper which in turn results in a soft brake pedal feel after a long high speed straight. I experienced the same issue at VIR this past weekend braking for turn 1 and turn 14.
Franknbeans (06-29-2017)
Old 04-04-2007, 05:44 AM
THE TECH
THE TECH's Avatar
How in the hell does the piston travel back into the caliper? I've never heard of such a thing.
Old 04-04-2007, 05:46 AM
Nihilation
Nihilation's Avatar
Don't quote me on this but at VIR I was told it happens because "The little amount of play that the rotor has at high speed is enough to push the pads outward, forcing the piston to recess back into the caliper."
Old 04-04-2007, 06:30 AM
commasense
commasense's Avatar
Here it is.
Search on "knockback." We've had several threads on it.
It's quite common in the Z because of the angle at which the front calipers are mounted. In hard corners, the hub flexes enough to push the pistons back a few millimeters. As a result, when you hit the brakes the next time, the pedal travels farther than you'd expect before starting to grab.
I've gotten completely used to it, and either tap the brakes a little before the start of the hard braking zones, or just expect the pedal travel and deal with it.
I suspect that if you track your Z and haven't experienced knockback, you're not taking the corners fast enough!
Old 04-04-2007, 06:37 AM
John
John's Avatar
Pad knockback. Flex in the hub under heavy cornering loads will cause the rotor to become a fulcrum and push the pistons back into the caliper a small amount. The larger the rotor, the moe pronounced the pad knockback. The result is a friendly suprise going the next time you step on the brake as the pedal willl sometimes go to the floor.
As for the seals, I honestly don't see how these really work, but I can be humored...
Old 04-04-2007, 06:54 AM
THE TECH
THE TECH's Avatar
That's pretty crazy.
Quick Reply: Brembo Racing Anti-Knock Back Seals
